Destiny RX-10S
#48
Long time since last posted here at RcTech, sorry folks! I am back, even I wasn't gone
My setup for RX-10S TC can be found from my V-Dezign facebook, here is a link:
https://scontent-arn2-1.xx.fbcdn.net...5e&oe=5880B5ED
BR,
Vesa Yli
BR,
Vesa Yli
#49
New destiny??
Any news on a new car?
#50
fit & quality of parts is excellent ( right up there with the high end/priced kits )
Easy build ( instructions manual could be a little better )
No leaks from diff or shocks
Plastic out drives on front spool are weak ( get the steel ones straight from the start )
Have ran mine now twice on out door low grip surfaces, from kit build have only made changes to front & rear roll centres & the car is very planted, can put where I want,plenty of steering & a very consistent car to drive
With some more racing & trying some things it will only get better for me
Hope this helps
Hope this helps
#52
Destiny for sale
http://www.rctech.net/forum/r-c-items-sale-trade/964643-destiny-rx-10s-arr.html#post14702166
#53
#55
Just finished putting my car together this past weekend.
I need to know if anyone had some trouble with the rear axles during assembly. Mine are so tight I can't get the cross joint back out of it. Do they need to be broken in somehow?
Also the ball cups are not as smooth as I would like them to be. Can anyone suggest a replacement?
Thanks in advance.
Thanks in advance.
#56
Just put my car together this past weekend.
I was wondering if anyone had trouble putting the rear axles together. Mine are so tight I can't get the cross joint back out. Do they need to be broken in somehow?
Also the ballcups are not as smooth as I would like. Does anyone have a good solution for this?
Thanks in advance.
Thanks in advance.
#57
HI
About rear axle what are thight? for ballcup use ballcup and uniball by Yokomo
#58
The cross joint pushed into the aluminum axle is essentially ceased. it won't move.
The yokomo cups feel pretty good thanks for the advice.
#59
New parts
New products
O10148 carbon bumper upper brace
O10149 RX-10S Sterring rack, steel
On face book-Destiny Japan page
#60
the carbon bumper brace should be std in kit (imo) I have fitted an xray one to my cars, just a bit of protection for the front end of the chassis
