Destiny RX-10S
#287
Is anyone using the Aluminum Front Spool Center Holder[o10158]? Can this be used when running the 37t pulleys? I'm thinking the alloy spool is only for 40 tooth setup...??? Also, can someone tell me what length front belt I need for the 37t pulleys. I ordered the S3M516 (172T) white belt but that was way to long....I know I don't need this, stock belt is fine just want some bling.
not sure about the pulley. But for 37t pulleys, belt size depends if you are using front motor mounting option (front 510, rest 189) or rear motor mount option (front 513, rear 186). Note the center pulley mount is directonal, you have to flip the left piece and right piece around depending if you want rear or forward motor mount
#288
#292
Ran the car for the first time yesterday at my local asphalt track, car was very good Need to play with diff oil and shock oil but for a first outing it was good. Do you guys have any issues with the diffs leaking? Also, with the 37t pulley setup are you guys running the diffs high or low? The asphalt I run on is med to low bite.
#293
No leak8ng diffs and running them high.
#295
when i had the original i did have issues with my diffs leaking. seems like to me the gasket wasnt seating right
#299
You can send a message through High Velocity RC's Facebook page or send an email to [email protected]
#300
Anyone know where to find M2 shims for the hubs (2mm ID shims)?
