Tamiya TB-Evolution III >
Old 02-24-2004, 12:44 AM
  #5671
V12
V12's Avatar
Originally posted by markp27
Is there a way of adjusting the caster on the EVO III?
Cheers, Mark.
Hi Mark
Tamiya front hub carrier is 4° and the one from Square is 6° caster.
Otherwise you could change kickup using different shims at the front suspension blocks. Usually Iīm running 4° caster and 0° kickup.
V12 is offline
Old 02-24-2004, 12:52 AM
  #5672
V12
V12's Avatar
Hemi
difference between oneway and front diff is about 10 gramms.
Replacing all titanium turnbuckles and screws are about 20 gramms. Replacing the titanium turnbuckles is a good idea as the stock turnbuckles arenīt that good. But if you wanna go for a front diff I wouldnīt use the titanium screws as these are expensive and not as strong as steel screws. Iīm not using titanium screws at the bottom of the chassis especially outdoors.
V12 is offline
Old 02-24-2004, 01:04 AM
  #5673
markp27's Avatar
Originally posted by V12
Hi Mark
Thanks for the answer V12!
What is kickup? As per my Surikarn assembly instructions under the front suspension block (only the very front one) I have 0,6mm shims - Is this for the kickup?
markp27 is offline
Old 02-24-2004, 05:09 AM
  #5674
V12
V12's Avatar
Exactly this is kickup. But Iīm using no kickup with my EVO3 as I like less castor and from what I know there is no hub carrier with less than 4°.
V12 is offline
Old 02-24-2004, 05:28 AM
  #5675
markp27's Avatar
What affect on the handling does more kickup have?
markp27 is offline
Old 02-24-2004, 05:39 AM
  #5676
V12
V12's Avatar
usually kickup is better on a bumpy track and steering should be somewhat smoother but in general I like zero kickup better as itīs more direct.
V12 is offline
Old 02-24-2004, 10:04 AM
  #5677
markp27's Avatar
I'll try that out on Friday.
Can anyone compare the Protoform Alfa, Stratus and Mazda 6 for me?
I have the Stratus at the moment and find it really nice, but I'm not sure if it is the best body for my track, which is very small will quite a lot of slow tight corners.
Cheers, Mark.
markp27 is offline
Old 02-24-2004, 10:47 AM
  #5678
V12
V12's Avatar
Regarding the Alfa and Stratus it depends if you are speaking of the version 1 or 2 each.
The Alfa 1 has much more steering than the Stratus 1 but Stratus is easier to drive and more forgiving. Was my favourite body with all my cars until the TC3. But donīt works for me with the EVO3. Alfa1 worked very good on an older GM racing/Hong Nor TC4 using front diff. Never worked for me with a oneway.
Alfa2 have much more downforce than version1 but I donīt like itīs characteric.
Stratus 2 had not enough rear grip with the TC3 but is my favourite for the EVO3 now. Worked at every track since now. Just have finished the Mazda but have to try next time. But most people I know like the Mazda.
V12 is offline
Old 02-24-2004, 11:06 AM
  #5679
markp27's Avatar
I have the Stratus version 2 and it is a really nice body to drive - but there is also a version 2.1, no?
I like the look of the Maza, it seems to have a very big front spoiler - I'd be interested to hear if it increases the front grip.
But it is the driver still who needs to improve
markp27 is offline
Old 02-24-2004, 11:17 AM
  #5680
V12
V12's Avatar
the Stratus 2.1 is a 200mm wide version
from what I have heard the Mazda have lot of front and rear grip.
So maybe something like a Stratus 2 with more downforce.
V12 is offline
Old 02-24-2004, 11:49 AM
  #5681
markp27's Avatar
AHA! I didn't realise that the 2.1 was the 200mm version!
I think I'll order a Mazda - have you seen on Ebay you can get them for 19,99 Euro!!
Cheers, Mark.
markp27 is offline
Old 02-24-2004, 01:04 PM
  #5682
V12
V12's Avatar
Exactly there I got mine!
V12 is offline
Old 02-24-2004, 07:49 PM
  #5683
I would try running A blocks at socal. less toe more stearing good luck Robert
mugenracer is offline
Old 02-24-2004, 09:22 PM
  #5684
Originally posted by Tag
one more quick question, for the rear toe block, i currently run a " B " what degree of toe in does it represents ? what do you guys usually run for a relatively tight track like socal ? thanks
"B" should be .5 of a degree more than "A". "C" should be .5 of a degree more than "B". And the degrees go on from there. Another thing to mention, the rear hubs have a built in 2degrees of toe. So you add 2degrees to which ever block you are using.
Right now, whenever I run my EVOIII at SoCal, I have been using the "C" block, and I liked it. Maybe try 1 or 2 degrees of anti-squat...
Chris
Bubblestc3 is offline
Old 02-24-2004, 10:12 PM
  #5685
ngo8's Avatar
i have hubs that say 2 degrees on them but i also have some that dont say nothing am i assuming that they are 0 degrees hubs i use the now and they work fine.
ngo8 is offline
