Tamiya TB-Evolution III
#4757
Re: Diff
Originally posted by JoeySnow70
Just for curiosity, will the dear diff fit in the front diff housing, if so anybody have a part number for the complete unit. Any help is very appresiated, just bougth my Evo III and dont quite like the front oneway...
Joey
Joey
#4758
what do you guys do to stop the 26mm wheels hitting the top link ball joint?
#4759
Iīm using 1mm spacers between wheel hexes and wheel.
#4760
what do you guys do to use 26 mm wheels to stop from binding on the upper link?
#4761
#4762
Re: set-ups
Originally posted by madjack
Rod,
did you post your TA Nats set-up anywhere?
if not could you shoot me an e-mail....buddy...pal
JC
Rod,
JC
The 04 was good yesterday but it did not have the snap coming out of corners like the Ebo Tray does.
#4763
Could someone do me a favour and list all the drive train fixes for the evo for me
shimin, backin plates n so on.
who runs 2 diffs here, anyone experience skipping teeth in the front?
#4764
I was diggin through a box of spare parts and came across some #500 oil. Does anybody know how these other oils compare to the double digit oils? Like is #500 equal to 50 weight or is it some mathmatical calculation?
Coop
Coop
#4765
Thanx for the help V12
Joey
Joey
#4766
Originally posted by trf racer
its still binding with 2mm worth of spacers.
The only way I've successfully spaced it out is using either 2x 2mm spacers or 4x 1 mm spacers. The other way around it is to get a set up of the Plain Alloy hexes, they are 6mm.
Also, one of my mates just dropped his foams onto a tire truer actually cut 2mm off the rim, making it a nice 24mm foam.
hope that helps
#4767
Coop
Coop
#4768
Originally posted by Roger
500 is equal to 45 wgt.
Thanks for the feedback. I also have #300, #400 and #600 do you know how those convert?
Thanks,
Coop
#4770
Evo_uk
I run a diff in the front and never had a problem with it looks and ran great for my spring and fall season.
