Tamiya TB-Evolution III >
Old 08-06-2003, 10:52 PM
  #3196
PizzaDude's Avatar
Originally posted by WC
Yup, that's the one (53628).
So... more useful mounted Upfront?
Any use mounting one for the Rear too?
(gotta buy 2 packs if one wants it F & R)
Some of the Evo-3 tended to get tweaked . This alloy part helped a lot in prefenting that.Because ot is also the connection between gearbox and top-plate.
Also with side impact the upper arm link positions on the shock tower cracked.
These 2 things were also an important ssue in the usage of this part.
PizzaDude is offline
Old 08-07-2003, 03:32 AM
  #3197
Super Moderator
charlie_b's Avatar
Rod-what should i gear a 10 turn at Tamiya? I just got my Surikarn Evo3!
charlie_b is offline
Old 08-07-2003, 03:42 AM
  #3198
Today ... I tried my TB-EVO3 (Surikarn Limited) ... first time on the track
With my 21T Stock motor ...
I tried 62/35 (spur/pinion), fdr = 4.60 (Altough very fast, the motor was burning hot ... I even burt my fingers )
Then I tried 62/34, fdr = 4.74 (Even faster, better lap times and the motor was still very hot ... but less than before )
Do you think I am overgeared? With the final driver ratio at 4.74, it was very fast ... do you think I should keep trying until the motor does not get very hot or is it normal?
Raikonnen is offline
Old 08-07-2003, 03:50 AM
  #3199
defMondo's Avatar
Not sure how big your track is but it seems very much over geared to me. I would be trying starting at 5.8 or something then move 5.6, 5.4 etc until you notice the speed drop off and motor overheating.
But this is all based on 27turn Stock motors, I have never ran a 21 turn motor.
defMondo is offline
Old 08-07-2003, 08:32 AM
  #3200
rtypec's Avatar
Hey Charlie,
It all depends on what kind of motor you're running. I've been running a Krypton with a conservative ratio of 8.32 (96/30) At the reedy race they were well into the 7's. I'd try either 8.32 or 8.05 (96/31) to start with and go from there. Run time is no problem with this ratio and you have enough oompa loompa to get down the straight and through the sweeper with this.
Will you be down to Tamiya this weekend? If you have time, I've got a couple of TCS bodies that need some lovin. Could ya hook me up? I'll hook you up with something
rtypec is offline
Old 08-07-2003, 11:39 AM
  #3201
Aurra Sing's Avatar
Hi. With a 64pitch 96t spur (which seems to be what everyone is using), what is the lowest pinion I can use? I usually gear my 414M at around 8.5 or lower, so I would need a 29t pinion and 96t spur to be around there. Does this combo fit the Evo3?
Aurra Sing is offline
Old 08-07-2003, 11:58 AM
  #3202
rtypec's Avatar
Yes it does...I've gone down to a 28 with room to spare for something smaller. I'm not sure what the exact minimum was but it was getting pretty close.
rtypec is offline
Old 08-07-2003, 12:08 PM
  #3203
Super Moderator
charlie_b's Avatar
Some bodies need Loving? UMM..like a ROD-ZILLA theme?
Old 08-07-2003, 12:18 PM
  #3204
rtypec's Avatar
En-Oh No...haha nice try though, I was thinking about something relatively easy to see on track and not too busy. Like a flourescent blue version of a scheme that I saw. I may have something to help you motivate your Surikarn car. We can talk later if you want.
Other than that, nothing new with my ride...the surikarn's still in its box but the chassis been prepped. My current chassis (what's plural for chassis?) desperately need rebuilding. And I got some new springs to test this weekend...yum.
rtypec is offline
Old 08-07-2003, 12:28 PM
  #3205
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
eh heh, yeah and with plenty of CALSONIC Stickies
RedBullFiXX is offline
Old 08-07-2003, 02:16 PM
  #3206
Korey Harbke's Avatar
Has anyone found any info on those new springs that tamiya is coming out with?
-Sushi Boy
Korey Harbke is offline
Old 08-07-2003, 09:52 PM
  #3207
rtypec's Avatar
Pictures of Kazuo Muramatsu Stratus 2.0 Body
I know that the guys from the Seattle took like 52,301 pictures of the Reedy Race when they were down here and I would like to know if any of you have pictures of Kazuo Muramatsu car with the body on...It's the white, orange, black and yellow one that kinda looks like an opel when you squint your eyes. If any of you can post a picture or two of it that would be awesome. Thanks in advance!
rtypec is offline
Old 08-08-2003, 02:16 AM
  #3208
cHckbOY5's Avatar
wat hop ups are still needed in the evo s.... how come seems like not as much ppl running this car anymore? im plannin on getting one like at ebay or sumhting (how much should i pay max for one?) or is it time to jump on the cuda bandwagon?
cHckbOY5 is offline
Old 08-08-2003, 03:13 AM
  #3209
If you buy the TB EVO 3 (Sulikarn Limited), you will have all the important hopups included.
Today was my second day of practise. I went down from 4.60, 4.74, 4.88 and 5.00 as final drive ratio and the car still goes extremely fast
I am already making the best times of our track
I have only 1 problem though, using the default setup as per instructions, the car is a bit loose entering a corner (off power). How can this problem be solved
Old 08-08-2003, 03:27 AM
  #3210
GTMilenko's Avatar
1 way would be to try less rear droop
GTMilenko is offline
