Tamiya TB-Evolution III
#2641
well, I was messing with the setups and tried several... so far I REALLY like surikarns setup from the tamiya website...cept for two changes.... I took out the rear block's spacers and put associated gold springs up front instead of assoc. silvers... so far I can out corner everyone at my track.
Heck I just got a 2nd place trophy yesterday at a big race we had... I shoulda had 1st, but that went to the guy who clipped me going into a corner. :P I dunno bout you guys, but if I nail someone accidentally, I usually wait for him to pass me and then pass him clean the next time. I kinda feel bad about "taking people out" Not cool racing etiquette IMO.
#2642
-Sushi Boy
#2643
hey guys,
i forget who had them , but are those spools avaible for the general public yet? i would like one please, if someones selling them.
#2644
Originally posted by Evoracer
Good Morning All!
Could someone supply a good setup for asphalt/parking lot . It's a new track so I don't know the grip. Lets assume medium to high. Stock 27t. CS27 tires are my usual choice. track layout changes every month but usually pretty technical with only 1 long straight of 100 to 125 ft.
Bought this car used and it was set up for carpet. I made it through the first 25 or so pages of this thread but finally figured I'd just ask for help.LOL Thanks, Dino
Good Morning All!
I have been using this setup recently and it's been serving me very well.
Setup
The track you mentioned is similar to the one I first ran this setup on and it was like it was on rails.
Enjoy,
Tony
#2645
to all u guys with tamiya's heres a question.[iam also a tamiya driver].y do most people and all the team use the outer holes on the wishbones?
#2646
wishbones? which part are you refering to?
#2647
lower a-arms.everyone uses the outer hole for mounting the shocks.
#2648
thought so, just checking.
i presume its to get more of a laydown shock type setup.
the outter hole will make it stiffer(less leverage), and being more layed down the shock will get stiffer as it is compressed(as long as it doesn't go past 90degrees of the a-arm, in which case it will get softer as compressed).
adjust the a-arm shock mount for major adjustments.
adjust the shock tower shock mount for minor adjustments.
so i quess it gives more of a progressive suspension.
i got this info from the XXX main chassis setup guide.
#2649
i just 4ort because even in very loe grip tracks people use the outer holes.inner hole will give more grip?
#2650
no, from what i understand the outer hole gives more grip.
i'm about 95% sure on this, if no one bites my head off you can presume i'm rite
#2651
i 40rt that the more uprite the dampers the more grip.
#2652
nah, the more perpendicular the shock is to the a-arm the soft it will feel.
try it on you car. set one side with the most outer hole and the other with most inner. you can feel the difference by pushing the shocks up. i just tryed it out myself.
#2653
so if you want more grip youll have the shocks on the shock mounts outer most and on the a arms put them outer holes
#2654
no no, inner hole on the shock tower, outer hole on the a-arm
makes it more layed down. the more layed down the more grip.
i think this is why most gas touring cars have lay down shocks.
#2655
Guys,
Don't you get grip and stability mixed up.
The outer hole makes the car stabile, and more predictable.
The inner hole (due to leverage) gives more grip.
Shocks lay-down seems to give more side-bite and feesl as if the car is more direct.
but trough long corners a standup will work better.
Also standup keeps up the speed (momentum) through the corners.
Pizza
Pizza
