Team Associated TC7 & TC7.1 Touring Car
#1396
So the way I look at it, $275 plus $55 is $330 for the TC7. The TC7.1 can be had for around $410 if you have any Tower Coupons. So is it worth the $80 savings? That's a tough decision, I'd probably go with the 7.1, in the long run it will be the faster car. All the factory guys said they picked up some time with the 7.1.
#1398
Thank you. I will be running carpet so might as well go big out of the gate
I have both and run every Saturday on medium bite asphalt. I love both cars, but it's taken me some time to tune the 7.1 because it has more steering and for me that's not a good thing. I love my 7, but with some changes I've gotten the 7.1 to work well. For that money, I'd be tempted to go with the 7 unless you are running on carpet then I'd get the 7.1. But remember, once you get the 7, it will cost around $200 to upgrade, so if you think you will ever upgrade, buy the 7.1 now. Plus, you HAVE to get the steel front outdrives and the DCV's, that's another $50 to $60 you have to spend on the TC7 even if you don't upgrade it.
#1399
#1400
Front body post
I'am planning on running some Tamiya bodies for the USGT class at my local track. If the stock front body post aren't long enough to fit the bodies. What other brand of body post do you USGT guys suggest for my TC7.1?
#1401
Oops, you are absolutely correct. It will be around $300. I don't remember what the coupons was for $345 total, probably around $40 to $50 off. And the 7 is $290 at Tower, not the $275 he found. But he said he is going to run on high bite carpet, so with that info, I'd definitely go with the 7.1
#1402
Body post
I plan on running some Tamiya bodies for the USGT class at my local track. If the stock body post that come with TC7.1 are too short what other brand of body post do you USGT guys suggest that I use?
#1403
Scott
#1404
OK, I went 2 dots out on the front of my TC7.1 along with blue springs (15.8), I was 2 dots in with gray springs (14.8). I reset the front toe and camber and rebalanced the car. We'll see how that works this Saturday. Thanks for everyone's help.
I left my TC7 alone, 2 dots in on the front, gray springs all the way around. I think the TC7.1 has more steering and the good drivers like that, but I'm not in their league and I want a car that's a little easier to drive.
#1405
Well, the track was rather slippery this last Saturday, the experts were over a lap off their typical runs. The TC7.1 (21.5) was still a little loose coming out of the turns on power. So was the TC7 (17.5). Well, I'm going to load on the Randy Caster setup that he used at our track (Mesa, Arizona outside sealed asphalt). I'm putting .5mm of anti-dive in the rear of both cars, should be more stable on power. I also set the roll centers like Randy used and on the TC7.1 I will run the same progressive springs in the front (2.5-2.7) and the 2.7 springs in the rear. On the TC7, I'm leaving the gray springs all around. The only real difference from Randy's setup is I will continue to run 3 degrees rear toe instead of 2.5 (I need the stability) and I will run a little wider front track. We will see if this helps. My only problem is I hope I'm not chasing a set up just because the track was cold and slippery.
Scott
#1406
#1407
I thought about the modified, but it seems to me if he is not loose with a mod motor, I should be great with 17.5 and 21.5 motors. I'm kind of surprised that the track was not good yesterday, it really wasn't that cold out. Must have been the rain washing away our accumulated sugar coating.
#1408
