Team Associated TC7 & TC7.1 Touring Car
#1141
Running the Reflex short short tower on my 7 and I had bought the Yokomo slf2 shocks. I had a bear of a time getting a dead shock but finally got it done by swapping out the bladders for the Associated ones.
They seem a fraction of a mm out of size but they still work; so far.
Question is do I continue with these or do I use a different bladder; yokomo black? the original ones were pink.
I am assuming the stock bladders were the culprit on my frustrations.
#1142
#1147
did you put them on the right side?
#1151
help with tweak!!
I'm assembling a new tc7.0 kit and running into a small snag.
The problem:
I have the bulkheads, diff, spool and bearing caps bolted in. When I place the chassis on a piece of glass it feels very flat to the surface, IE - does not seem to have any tweak.
Now when I put the upper deck on it falls into place nicely and seems to line up good. If I tighten all the upper deck screws (in a X pattern) the chassis becomes slightly tweaked. It rocks a little when resting on the glass. Its not a huge amount but definitely not as flat as without the upper deck installed.
If I loosen the upper deck bolts enough that the upper deck can float slightly on the bolts, I notice the rear left and front right of the deck can float nice and free on the bolts. The right rear and left front does not float at all on the bolts, they bind by a small amount.
If I flip the upper deck over it still binds on the front left and rear right bolts. I tried to loosen the bulkheads then install the upper deck leaving all the bolts loose and then tightening everything slowly but it still is tweaked once tightened up. The belts are not too tight, same problem without front belt installed.
I'm not sure how to solve this. Can I ream out the holes on upper deck a little to stop the binding and hopefully fix the tweak? I'm starting to think one or more of the bulkheads was not machined correctly.
Thanks for any help
Dean.
The problem:
Thanks for any help
Dean.
#1153
It is probably a difference in thickness in the anodizing between the bulkheads. A little sanding and you'll be good to go....
The problem:
Thanks for any help
Dean.
The problem:
Thanks for any help
Dean.
#1154
The problem:
Thanks for any help
Dean.
The problem:
Thanks for any help
Dean.
