Team Associated TC7 & TC7.1 Touring Car
#1097
YES, I will be back at the track once I get the last tc4 lightweight parts from Dynotech Racing... It should be fun to race against all you guys with your new cars: Tc7, 7.1, etc...
All I've been doing is light upgrades to get my car down to 1310grams(from1448grams), in time for the new roar tc minimum weight limit...
See you at the track soon....
#1098
Which alum chassis
Okay I see yes for the alum chassis
Which one would be the best?
Associated, RSD, does Avid have one foe TC7, other?
Thanks for all the help guys
God Bless
God Bless
#1102
those earplugs...my god i love it!!!
#1103
Shes almost finished!
#1104
Nice paintsheme !
#1105
Just ordered two 7.1's. Do you guys have any build tips? Got 2 alu chassis too.
#1106
make sure your arms fall under their own weight no bind. depending on the spur you use the screws do not tighten enough to keep the spur from wobbling unless you install some very thin washers under the aluminum plate they the spur bolts to. Make sure you double check the belt tightness by adjusting the cam correctly. I got mine wrong. think about some very thin washers under the servo mount plate to ensure the servo is not touching the chassis and letting it flex freely.
#1107
#1108
i have a tc7 box stock if i run the cva in the front of the car and not the dvc will the car back end come around in a tight corner. because the front is locking up or is it the setup. thanks
#1109
Depends on the servo. For Sanwa BLS / 801 I use 0.5mm between the alloy and the top carbon servo plate. If you're going to mount it all to the servo posts (as per kit) then you'll need 0.5mm on top of the steering posts as well.
#1110
Thank you for the quick reply, now I understand what I have to do. Keep the gap between the servo and chassis as small as possible but make sure it is floating. All depends on the brand because of different sizes.
