Team Associated TC7 & TC7.1 Touring Car
#3019
Does anyone know what size pin is used in the inner dcj shaft that rides in the spool out drives and where to get them? I measured mine at 1.8mm x 10mm, but I am not finding that size readily available. I have several worn drive pins and want to replace those instead of putting new drive shafts in. That seems wasteful.
Thanks in advance!
Thanks in advance!
#3021
Had a first run on our low grip asphalt track and car has a mix of asphalt setups from petit rc.
Feels really loose on the rear, especially at corner exit (its more like a rallye car)....what can I do? Rear Diff 5k, shocks ~35wt with 2.5-2.8 front and 2.6 Rear (Xray)
#3022
I have pushed the pin out of one of my old ones. I was hoping to just replace the pin vs. replacing the whole shaft. I have to replace at least 4 of them, and have to do it a couple of times a year. Its a lot cheaper to replace the pin then the whole thing!
Thanks!
#3023
Try here: https://www.mcmaster.com/pins
more than likely the 1.8mm is a 1.5mm depending on the quality of calipers you're using. I have some cheap digital ones (I keep in my pit box) versus some really expensive ones I keep at home, and the measurement can vary between the two by up to 0.5mm. If you're positive on the 1.8mm you could shoot them an email, or call.
#3024
#3025
What motor or class are you running you’re car in? I’ve run everything from 4.5 to a 17.5 blinky and haven’t worn out any pins. I think I’ve worn the outdrive before the pin. There is a guy that races locally that was selling a bunch of new driveshafts that he didn’t need anymore, maybe you can get the pins out of these? ( message me privately and I’ll send you his name on here and FB). I’ve never heard of anyone having any luck replacing the pins though. They always seemed to eventually come out of the driveshaft causing a spin and more damage to the car.. Just a suggestion, either way I hope you can get it fixed.
#3027
I have read that off-road racers do this all of the time. There are even tools out there to do it quick and easy, but they are meant for 3mm pins, and these definitely are not 3mm.
#3030
Correct....I use Amsoil 5% moly grease with the same results: no significant wear at all.......I also prefer the grease over those plastic blades that keep breaking off....
