Team Associated TC7 & TC7.1 Touring Car >
Like Tree395Likes
Old 06-26-2018, 03:25 PM
  #2791
Perhaps the thought is, with that belt configuration, you can tuck the battery more inboard to balance the car out easier. Allowing a bigger mah/heavier battery. The picture shown has the inner battery terminal tucked in quite a ways.
Rodney Racer is offline
Old 06-27-2018, 01:11 AM
  #2792
gigaplex's Avatar
Unlikely, and possibly the opposite. The motor is moved more inboard meaning that it'll take less weight battery side to balance things out, and the battery won't be able to move too far in without hitting the pinion.
JC3 likes this.
gigaplex is offline
Old 06-27-2018, 07:53 AM
  #2793
RobS's Avatar
Hopefully the retail price stays reasonable compared to other brands. Otherwise I might be tempted to try something else.
DavidNERODease likes this.
RobS is offline
Old 06-27-2018, 09:01 AM
  #2794
JC3
JC3's Avatar
This seems to be a high wear item on the rear CV's. Is anybody replacing just the pins? Never seen it talked about. Also, are these perhaps the same pins that RSD sells, the size is the same.
JC3 is offline
Old 06-27-2018, 09:26 AM
  #2795
theproffesor's Avatar
Trader Rating: 66 (100%+)
I had my car for over a year, that I bought used, and never saw any wear on the pins. You are going to wear out the outdrives before the pins.
Unless ash you’re running mod or 17.5 2-3 times a week, I highly doubt you’ll ever replace these. You’ll probably cause more damage to the axle while attempting to replace it than it’s worth. Just get new axles if you feel they need to be replaced
theproffesor is offline
Old 06-27-2018, 09:29 AM
  #2796
Edit. Just realized you said rear... are you not running the shoes on the pins??? You know the C shaped plastic parts that go over the pins that slide inside the outdrives? If not you need to get those.
Old 06-27-2018, 04:15 PM
  #2797
Matt Trimmings's Avatar
Trader Rating: 170 (100%+)
Yeah, that end of the bone is basically zero wear.
Matt Trimmings is offline
Old 06-27-2018, 08:28 PM
  #2798
JC3
JC3's Avatar
That other picture is actually the new one. Swapped it out tonight. The pin on this thing is all worn out as is the DCJ itself. It's the one on the right. Pic doesn't show it but one side of the pin is flat. Everything else is fine. No wonder it was so sloppy in the car.
JC3 is offline
Old 06-27-2018, 09:05 PM
  #2799
gigaplex's Avatar
You haven't said if you're using the 31238 blades that you're supposed to be using on the rear CV axles. There will be massive play if you're not using them.
gigaplex is offline
Old 06-28-2018, 04:42 AM
  #2800
JC3
JC3's Avatar
I should have been more specific. This one was on the front left. The front right was also slightly worn. Like other front DCJ's I've seen, the flange was busted off of the axles. So, they were due for an overhaul or replacement.
The rears were a bit worn too. The blade holes were a bit opened up and oval. I swapped the CV's on both sides as well. Rebuild on them coming up.
If the axles are in good shape, I still want to try and replace the pins. Might be a fun project. Thanks guys.
JC3 is offline
Old 06-28-2018, 05:23 AM
  #2801
If the bladesare worn then you can replace the blades. In my experience, getting drive pins out of AE axles is more of a chore than its worth. The pins arent exactly press fit in like other manufacturers. They are in there pretty solid.
You initially said rears, but since you are talking about fronts...yes they will wear, especially with the steel spool outdrives vs the plastics. They may last longer with the plastic outdrives but then you'll be wearing the outdrives more. It's a trade off.
JC3 likes this.
Old 06-28-2018, 11:49 AM
  #2802
Lone Drifter's Avatar
Don' hold your breath on that one or your Face will be as Blue as Associated aluminum
My Guess is that will be just over $500 . Just Because......
Lone Drifter is offline
Old 06-28-2018, 12:54 PM
  #2803
This is my main frustration with Associated. The kits seem a little overpriced - not horribly but just enough to make it hard to choose them over the other dozen or so good quality not made in North America kits.
DavidNERODease is offline
Old 06-28-2018, 02:02 PM
  #2804
RobS's Avatar
As long as it doesn't start approaching Xray/Awesomatix territory just because that's what those guys charge, I'll be happy. I do expect it to be more then what the 7.1 was though.
RobS is offline
Old 06-28-2018, 02:09 PM
  #2805
no worries, associated has the best parts support in US. While team mica blue price their chassis at around 800-1200 usd range which is really insane.
JC3 likes this.
zxcvb1t is offline
