Team Associated TC7 & TC7.1 Touring Car
#211
http://walliebuilds.com/ is going to offer premium TC7 Builds by Randy Caster... should be some dialed build tips forthcoming I'm sure...
#212
With the likes of Xray, Yokomo, Tamiya and VBC does the TC7 comewith them, or as an option
#213
The Evicerator
The shocks were designed around "full length" springs, so your collection of other springs should work just fine!
#214
OK, I took the sway bars apart again. The aluminum center sections were slightly too long and rubbing hard. I sanded the ends down with coarse sand paper followed up with a very fine sand paper to give it a nice finish. Now the sway bars rotate freely. I wonder if anyone else has had this issue?
#215
As to your other question, yup, HPI springs should be absolutely fine.
I know Chris has used Yokomo springs and tried Xray short springs. So I think the message is that you should be able to use pretty much any spring!
#216
The build is going awesome, taking my time and getting small steps done on my breaks and what not at work. The new plastics are awesome.. B5m quality. Not sure if it was carried over from the 6.2 but the way the caster/steering block connects without the caster bushing is great! My only "tip" so far is you are installing the DCV (#31632) read the instructions and install the 5x10x3 (not included) and not the included 5x10x4 .. I also slightly sanded the arms where the inner hinge pin goes in to free them up a little.. AWESOME KIT!
#217
can i use these fox shocks as an upgrade on my tc6 chassises?
#219
sweet. think i'll look into ordering some xray springs to couple these with
#221
#224
And I do not believe that the TC7 comes with them in the box.
#225
Correct, TC7 does not come with DCJ in the box.
