BSR Racing BT4 Budget Touring car kit
#481
I'm using the 21.5 RTR version for USGT. Only tires and gearing change. Stock servo been solid to me.
#483
Honestly never really looked at specs on servo. Just went with it how it was. Here's from my last race. I made a mistake with gearing, it worked but was wrong. But still ran solid.
https://youtu.be/QdHHdsH46ls
#484
I have a question about the springs. The kit came with 30N springs, 25mm uncompressed length. I like stiff front springs, but I needed softer in the rear as I have lost of oversteer. I bought the springs from HK’s BT-4 parts section, but these are, although softer, only 20mm uncompressed length. Why? On my Tamiya racers I had equal lengt hall around, I read somewhere shorter front springs can help reduce oversteer, but now I have short soft springs in the rear and long stiff ones in the front. Doesn’t sound right.
I found my Tamiya springs don’t fit, what springs / spring set do you guys run? I considered to upgrade to TRF damper set with spring set, but I don’t want to spend that now.
While looking for springs on the HK site, I also saw the progressive damper insert set. Any thoughts on that?
Cheers,
Hugo
Cheers,
Hugo
#485
Cheers,
Hugo
Cheers,
Hugo
#486
I just did and it helps. What bars are you running? I have 1 in the back and 1,3 in the front. BTW, I run a very long asfalt track.
Hugo
Hugo
#488
#489
Race day #7. Practice only. Limited turnout
https://youtu.be/g4ajjDv9y48
Was trying 37/75 gearing. Still not quite right.
#491
With that said, I'd like to get into racing, most likely VTA as that's the most popular class at my "local" track. Would you choose this car over the TT02 or the Xi Sport?
#492
Thanks, I really love your reviews. They're very helpful, especially the race experience, since there's a strong idea that you need to spend a lot of money to do well, and you regularly disprove that with budget cars like this one, the Xi Sport and the TT02.
#493
I race my BT-4 in a really fast local class (10.5T motors, timing of my motor is at 47 degrees). I compete against XRays, HBs, and other big name cars. And th BT-4 holds up, although I cannot drive well enough yet. In the hands of one of our better drivers it goes really well. The only mods out of the box I have are adding sway bars, softer rear springs, mandatory tires for the class I race and a Protoform Mazda body. I run a cheap esc, the XCar from HobbyKing reprogrammed with HobbyWing firmware, and the TrackStar 10.5T motor. I have the cheapest car on the track, it is one of the fastest on the straight and in the hands of a good driver it is certainly A-final material.
Cheers,
Hugo
Cheers,
Hugo
#494
Thanks guys, that’s great to hear.
#495
Race day #8. Practice and 3 rounds.
https://youtu.be/pnRlMgxVq1c
I think it's time to try switching to 64p gearing. Just can't seem to get it right. I was able to put drive a car running much quicker laps again. But I'm tired of being 2 seconds off pace. So far I've used 33,34,35/69 and current 37/75.
