Awesomatix A800/A800R >
Like Tree2286Likes
    Hide Wikipost
Old 03-29-2023, 11:28 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Awesomatix A800/A800R
Last edit by: hanulec
A800R Released March 23, 2023 with two kit versions, A800RA (alloy) and A800RC (carbon)
Mid Motor Content ---
New Part Releases
  • January 2020 - A800-AM24-20 Servo Holder - combine servo holder and steering holder to one single part.
  • February 2020 - A800-ADC Advanced Damper Cup Set - Reduces the amount of rebuild routines. It offers the possibility to A) remove air and B) add oil into the damper without the need of full disassembling
  • January 2021 - A800-BDL - Body Downtravel Limiter, replaces SPR08
  • March 2021 - A800-P138LFA - 38T Pully Low Friction - For Gear Diff
  • March 2021 - A800-P138S-LFA 38T Spool Pulley Low Friction - For Spool
  • April 2021 - A800-C27MMX - Full Length Top Deck for A800MMX
  • May 2021 - A800-C01MMA Alloy Chassis - Battery position is shifted to the front to achieve a better overall weight distribution. Removes short arm holes. New narrower shape
  • September 2021 - A800-C04M1+7.0 Arm - narrows the track width for lower grip levels
  • October 2021 - AM180EVO Single Bellcrank Steering Update - AM180EVO is a direct replacement for AM180M5
A800MMX and A800MMXA Kit Updates
  • AM152/AM24-8 is replaced by AM24-20 in this kit (UPDATE 08.03.2021)
  • P138/P138S is replaced by P138-1/P138S-1 in this kit (UPDATE 25.03.2021)
  • C01B-X-MMA is replaced by C01MMA in MMXA kit (UPDATE 26.05.2021)
  • AM180M5 is replaced by AM180EVO in this kit (UPDATE 21.09.2021)
Below OLD Rear Motor Content ---
Welcome - please help to make this Awesomatix A800 wiki useful!
A800 Information
New Parts
  • June 2016: A800-SPR01-98 - The version of SPR01 springs with reduced angle of the tips bending. Recommended for using with new SPR02H3 Shock Rod Guides.
  • June 2016: A800-SPR01S-98 - The version of SPR01S springs with reduced angle of the tips bending. Recommended for using with new SPR02H3 Shock Rod Guides.
  • May / June 2016: A800-AM14A - includes new optional "longer" hole on steering arm
  • May / June 2016: A700-AM14-3 - removes the prior "longer" hole on steering arm
  • May / June 2016: A800-C04AL+0.5 - 0.5mm wider alloy suspension arm
  • May / June 2016: A800-C01B-2.25 - 2.25mm carbon main plate (best suited for asphalt racing)
  • May / June 2016: A800-D2.2 - Dampers that support a thicker SPR02H3
  • May / June 2016: A800-SPR02H3 - Thicker Shock Rod Guides for the D2.2 damper
  • May / June 2016: A800-AT41-2 - Damper vane for the D2.2 damper designed to work w/ SPR02H3
  • May / June 2016: A800-SPR02H - Stronger Shock Rod Guides for the D2.0 and D2.1 damper versions
  • May 2016: A800-AM19-4 - Currently used in the rear of a kit. With AM19-4 the top link effective length is 0,7mm shorter compare to AM19-2. Also with AM19-4 the flex of suspension is smaller ( similar to more stiffer arm and c-hub of normal cars). The screws on dampers are more accessible for adjustment.
  • January 2017 - SPRO2X - new for dampers and do not require a 98 degree bent spring.
  • January 2017 - New A800X and A800XA kits now available featuring 0.3mm longer front and rear wheelbase.
Kit Updates
  • May - Current: Kits now including DT10-2-1 bearing holders for increased side play and durability of the differential and spool.
  • May - July 2016: bearings within kits require oil before use
  • May / June 2016: C01B-AL (Khaki) Chassis with 0.5mm/side wider front arm mounts
  • May / June 2016: 2x ST17-1-S replace ST17 - See page 21 of manual
  • May / June 2016: Updated damper, D2.2, introduced
  • May / June 2016: Thicker Shock Rod Guides for the D2.2 damper included with kits, A800-SPR02H3
  • Jan 2016: GD2 Output Axle (ST31-1) update to use blue foam (P46) instead of set screw (used on each side of Axle after assembly)
Setups
Major Race Wins
  • 2016 Reedy Race of Champions - Modified - Julian Wong
  • 2016 Mile High Championship - 17.5 - Kyle Klingforth
  • 2016 Mile High Championship - 13.5 - Kyle Klingforth
  • 2016 ROAR On-Road Carpet Nationals - 17.5 - Mike Gee
  • 2016 ROAR On-Road Carpet Nationals - 13.5 - Mike Gee
  • 2015/6 ETS Season 9 Round 3 - Xray Pro Stock Division - Tony Streit
  • 2015 US Indoor Champs - 13.5 - Mike Gee
  • 2016 Roar On-Road Asphalt Nationals - 13.5 - Mike Gee
  • 2016 Roar On-Road Asphalt Nationals - 17.5 - Sam Isaacs
  • 2016 International Indoor Championships (IIC) - 17.5 - Mike Gee
  • 2016 Halloween Classic at the Gate - 17.5 - Brad Johnson
  • 2016 US Indoor Champs - 17.5 - Sam Isaacs
  • 2016 US Indoor Champs - 13.5 -Matt Lyons
  • 2016 Stock Wars - 17.5 - Mike Gee
  • 2016 Hudy Indoor Championship - 17.5 - Brad Johnson
Print Wikipost
Old 05-21-2016, 06:15 AM
  #1231
R/C Tech Elite Member
Jamison R's Avatar
Trader Rating: 66 (100%+)
Originally Posted by jmoneym
I ran car first time last week. Diff leaked so guess that tip is a must. Thinking slight heavier but little less to compensate for expansion.
The lighter method is really easy. Just remember to take the pulley off.
Jamison R is offline
Old 05-21-2016, 06:35 AM
  #1232
hanulec's Avatar
Trader Rating: 28 (100%+)
and sometimes the leakage is due to an over fill..
there are various tricks, but in reality my diff is the most consistent when i maintain it by re-filling. this isn't the difference between the car driving well or not --- but i can be the difference between winning and losing the A!
hanulec is offline
Old 05-21-2016, 05:02 PM
  #1233
Schwarta's Avatar
Will the at21+2.0 be released?
On both Max's and Viljami's setup, they use 0.5mm under the centre stiffener? What does that do? Reduce the effect of the stiffener on chassis stiffness?
Schwarta is offline
Old 05-21-2016, 07:16 PM
  #1234
bkspeedo's Avatar
The shims under the brace help let the chassis twist a little more than without.
bkspeedo is offline
Old 05-23-2016, 12:43 AM
  #1235
Tof
Hello everybody,
When is the chassis 2.25 will be available?
Tof is offline
Old 05-25-2016, 11:51 AM
  #1236
I am very happy how the A800 performs, but I am missing some turn in at high speed sweeps. It seems like it just slides over the front tires, missing some grip. I only run on carpet.
Any suggestions on what to try of setup changes to get some more grip in that specific situation.
my currently setup is attached
Attached Thumbnails Awesomatix A800/A800R-a800_editablesetupsheet-page-001.jpg
Shock Tower is offline
Old 05-25-2016, 12:15 PM
  #1237
It seems you run at low track asphalt.
Try petit rc and get the set-up of Ed IJzerman MACH Heemstede, I know it is modified but my fellow mate did this with his Stock 13.5 A800 and he could afford much highers corner speed, it is worth trying i tell you, good luck.
Next time give a full set-up sheet, and type of track/asphalt we can judge the situation more precisely.
eded1 is offline
Old 05-25-2016, 12:19 PM
  #1238
Well noted. I only run on carpet. I just put that info in my post. Thanks for pointing that out.
Old 05-25-2016, 02:55 PM
  #1239
hanulec's Avatar
How much drag do you have on the front of your chassis?
Two things that I notice with your current setup
Number one the front dampening / spring rate is very soft
Number 2 your arm height is very high
hanulec is offline
Old 05-26-2016, 04:07 AM
  #1240
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Default new parts and review of AM87
SPR01-98
new version of the SPR01 springs with reduced angle of the tips bending.
SPR01S-98
new version of the SPR01S springs with reduced angle of the tips bending.
C04AL +0.5
Alloy version of the C04M +0.5
I have been using the new bumper brace (AM87) for the ABS and it is rock solid! Way nicer looking and also stops any movement of the front bumper on the ABS.
Thanks,
Leonard.
DirtyDog3375 is offline
Old 05-26-2016, 04:09 AM
  #1241
Originally Posted by Markus
Someone make Awesomatix how-to videos On YouTube!
Good guide to get you started
Old 05-26-2016, 04:14 AM
  #1242
Jamison R's Avatar
Originally Posted by DirtyDog3375
SPR01-98
SPR01S-98
Cant we just bend the spring a little? Ive seen this done before.
Old 05-26-2016, 04:44 AM
  #1243
Schwarta's Avatar
SPR01-98
SPR01S-98
C04AL +0.5
Thanks,
Leonard.
Are you using the ABS Leonard?
Schwarta is offline
Old 05-26-2016, 05:03 AM
  #1244
Yes. Been using it since I got the A800. It's so simple and works so well!!!
Old 05-26-2016, 06:47 AM
  #1245
Do you have the guide for setting up the A800, especially setting the spring rate. How can I translate the spring rate in the setup posted on petitrc onto the car? Thanks.
N15M0 is offline
