Awesomatix A800/A800R >
Like Tree2278Likes
    Hide Wikipost
Old 03-29-2023, 11:28 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Awesomatix A800/A800R
Last edit by: hanulec
A800R Released March 23, 2023 with two kit versions, A800RA (alloy) and A800RC (carbon)
Mid Motor Content ---
New Part Releases
  • January 2020 - A800-AM24-20 Servo Holder - combine servo holder and steering holder to one single part.
  • February 2020 - A800-ADC Advanced Damper Cup Set - Reduces the amount of rebuild routines. It offers the possibility to A) remove air and B) add oil into the damper without the need of full disassembling
  • January 2021 - A800-BDL - Body Downtravel Limiter, replaces SPR08
  • March 2021 - A800-P138LFA - 38T Pully Low Friction - For Gear Diff
  • March 2021 - A800-P138S-LFA 38T Spool Pulley Low Friction - For Spool
  • April 2021 - A800-C27MMX - Full Length Top Deck for A800MMX
  • May 2021 - A800-C01MMA Alloy Chassis - Battery position is shifted to the front to achieve a better overall weight distribution. Removes short arm holes. New narrower shape
  • September 2021 - A800-C04M1+7.0 Arm - narrows the track width for lower grip levels
  • October 2021 - AM180EVO Single Bellcrank Steering Update - AM180EVO is a direct replacement for AM180M5
A800MMX and A800MMXA Kit Updates
  • AM152/AM24-8 is replaced by AM24-20 in this kit (UPDATE 08.03.2021)
  • P138/P138S is replaced by P138-1/P138S-1 in this kit (UPDATE 25.03.2021)
  • C01B-X-MMA is replaced by C01MMA in MMXA kit (UPDATE 26.05.2021)
  • AM180M5 is replaced by AM180EVO in this kit (UPDATE 21.09.2021)
Below OLD Rear Motor Content ---
Welcome - please help to make this Awesomatix A800 wiki useful!
A800 Information
New Parts
  • June 2016: A800-SPR01-98 - The version of SPR01 springs with reduced angle of the tips bending. Recommended for using with new SPR02H3 Shock Rod Guides.
  • June 2016: A800-SPR01S-98 - The version of SPR01S springs with reduced angle of the tips bending. Recommended for using with new SPR02H3 Shock Rod Guides.
  • May / June 2016: A800-AM14A - includes new optional "longer" hole on steering arm
  • May / June 2016: A700-AM14-3 - removes the prior "longer" hole on steering arm
  • May / June 2016: A800-C04AL+0.5 - 0.5mm wider alloy suspension arm
  • May / June 2016: A800-C01B-2.25 - 2.25mm carbon main plate (best suited for asphalt racing)
  • May / June 2016: A800-D2.2 - Dampers that support a thicker SPR02H3
  • May / June 2016: A800-SPR02H3 - Thicker Shock Rod Guides for the D2.2 damper
  • May / June 2016: A800-AT41-2 - Damper vane for the D2.2 damper designed to work w/ SPR02H3
  • May / June 2016: A800-SPR02H - Stronger Shock Rod Guides for the D2.0 and D2.1 damper versions
  • May 2016: A800-AM19-4 - Currently used in the rear of a kit. With AM19-4 the top link effective length is 0,7mm shorter compare to AM19-2. Also with AM19-4 the flex of suspension is smaller ( similar to more stiffer arm and c-hub of normal cars). The screws on dampers are more accessible for adjustment.
  • January 2017 - SPRO2X - new for dampers and do not require a 98 degree bent spring.
  • January 2017 - New A800X and A800XA kits now available featuring 0.3mm longer front and rear wheelbase.
Kit Updates
  • May - Current: Kits now including DT10-2-1 bearing holders for increased side play and durability of the differential and spool.
  • May - July 2016: bearings within kits require oil before use
  • May / June 2016: C01B-AL (Khaki) Chassis with 0.5mm/side wider front arm mounts
  • May / June 2016: 2x ST17-1-S replace ST17 - See page 21 of manual
  • May / June 2016: Updated damper, D2.2, introduced
  • May / June 2016: Thicker Shock Rod Guides for the D2.2 damper included with kits, A800-SPR02H3
  • Jan 2016: GD2 Output Axle (ST31-1) update to use blue foam (P46) instead of set screw (used on each side of Axle after assembly)
Setups
Major Race Wins
  • 2016 Reedy Race of Champions - Modified - Julian Wong
  • 2016 Mile High Championship - 17.5 - Kyle Klingforth
  • 2016 Mile High Championship - 13.5 - Kyle Klingforth
  • 2016 ROAR On-Road Carpet Nationals - 17.5 - Mike Gee
  • 2016 ROAR On-Road Carpet Nationals - 13.5 - Mike Gee
  • 2015/6 ETS Season 9 Round 3 - Xray Pro Stock Division - Tony Streit
  • 2015 US Indoor Champs - 13.5 - Mike Gee
  • 2016 Roar On-Road Asphalt Nationals - 13.5 - Mike Gee
  • 2016 Roar On-Road Asphalt Nationals - 17.5 - Sam Isaacs
  • 2016 International Indoor Championships (IIC) - 17.5 - Mike Gee
  • 2016 Halloween Classic at the Gate - 17.5 - Brad Johnson
  • 2016 US Indoor Champs - 17.5 - Sam Isaacs
  • 2016 US Indoor Champs - 13.5 -Matt Lyons
  • 2016 Stock Wars - 17.5 - Mike Gee
  • 2016 Hudy Indoor Championship - 17.5 - Brad Johnson
Print Wikipost
Old 11-10-2016, 09:58 AM
  #1981
Magnet Top's Avatar
Originally Posted by arn671
Anyone have spr02h that they would like to sell? Took a break from racing and am freshening up the car, trying to avoid having to buy the at41-2 just to use the more durable springs. Thanks in advance.
Alvin, I have a set you can have. NP
Magnet Top is offline
Old 11-11-2016, 08:37 AM
  #1982
Any idea when the at 41-2 will be back in stock on amx.com or when amxusa will have more than 2? Tired of bending the spr-02 And spr02h seem to be mythical parts.
doug smith is offline
Old 11-11-2016, 08:49 AM
  #1983
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
They are coming in and out right now
Will order more wheb available...
hanulec is offline
  #1984
Company Representative
Trader Rating: 15 (100%+)
Doug if you can't find any, I have some spares to help you out- also Dwayne F is selling 2x800s in our section as he is switching because of a new sponsor.. might be a good opportunity for you .. if you want txt me and I can talk to him as he is also attending round 3 this weekend.
Korgae is offline
Old 11-14-2016, 10:56 AM
  #1985
Trader Rating: 40 (100%+)
My A800a developed some clicking noise turning right this weekend and wondering if anyone encounter the same issue. Car has two race weekend since new.
Thanks.
joech is offline
Old 11-14-2016, 11:23 AM
  #1986
Trader Rating: 14 (100%+)
Default Gears
Is everyone running stock gears or X-ray? And what X-ray set there's three part numbers
john holmes 69 is offline
Old 11-14-2016, 12:21 PM
  #1987
geeunit1014's Avatar
Thanks.
Check the wheels, the arms can rub on the wheels under full lock.
Spur gears? I prefer RW gears
geeunit1014 is offline
Old 11-14-2016, 12:28 PM
  #1988
Schwarta's Avatar
I'm pretty sure he's talking internal diff gears.
I just use stock.
Schwarta is offline
Old 11-14-2016, 05:17 PM
  #1989
Default Gears
Yes I was referring to the gear diff internals
Old 11-14-2016, 05:20 PM
  #1990
Trader Rating: 90 (100%+)
Bill Sydor had his Aweso's super dialed the Midwest Indoor Champs.
RBLove is offline
Old 11-15-2016, 05:26 AM
  #1991
RC Professor's Avatar
Trader Rating: 17 (100%+)
I use the stock ones. No need for Xray gears that I've seen.
RC Professor is offline
Old 11-15-2016, 06:22 AM
  #1992
It sounds normal when I tested it on the bench even under full lock. And I also tried turned down the D/R and the noise still there.
joech is offline
Old 11-15-2016, 06:51 AM
  #1993
jlfx car audio's Avatar
Trader Rating: 37 (100%+)
It a bearing in a hub . Probably a inner if I had to guess .
The inner race will crack and under side load it will click
jlfx car audio is offline
Old 11-15-2016, 12:40 PM
  #1994
Has anyone tried running the new wider camber link holder on the front and back?
008-Racer is offline
Old 11-15-2016, 07:13 PM
  #1995
hanulec's Avatar
what part?
hanulec is offline
