Like Tree18Likes
Tamiya TRF102
Old 08-10-2015 | 02:50 AM
  #121
Hey guys, I am pretty new to the F1 RC cars. I recently picked up a TRF102 and finished the build already except for installing the esc.
My question is that i wanted to place the esc in front of the motor and have the battery behind the servo; but since the trf 102 has that flex plate. Wouldn't placing the esc on that flex place affect the flex and travel?
I will try to post some pictures of my build once i am done, if someone can post a picture of their electronics placement. That would be great.
Dynasty2382 is offline
Old 08-10-2015 | 02:51 AM
  #122
ShadowAu's Avatar
Originally Posted by Alan.Chow
I am using the 1.5mm T-Bar and yes, saucing the tyres as well.
the other t-bar is 1.8mm
try saucing the front more or rear less - like I said I've never been a fan of saucing
ShadowAu is offline
Old 08-10-2015 | 02:53 AM
  #123
ShadowAu's Avatar
You absolutely should not mount anything on the flex plate/t-bar - its what makes the rear suspension work
ShadowAu is offline
Old 08-10-2015 | 03:13 AM
  #124
Put a clear lexan on top of a thin sponges, there you have a platform to put an ESC on. It works for me.
Alan.Chow is offline
Old 08-10-2015 | 05:04 AM
  #125
Originally Posted by ShadowAu
Ok for the front - try more toe out
Rear - try the stiffer t-bar
As much as I personally hate using it, are you saucing the tyres?
Thank, I will try this next weekend (more camber, more toe-out).
The stiffer t-bar is built in already.
I sauced front und rear tires equally. I will do some experiments here next time.
Ronald
weber2406 is offline
Old 08-10-2015 | 09:46 AM
  #126
If you try to put a shorty lipo in the front, you can also put a screw on the main post (BA18)
It can act as a lipo holder there
Old 08-10-2015 | 07:13 PM
  #127
Thanks for the info. Would you mind letting me know how to keep the shorty lipo up front in place? Do you strap it down?
Old 08-12-2015 | 01:07 AM
  #128
ShadowAu's Avatar
Still a bit to do but I am liking it so far
ShadowAu is offline
Old 08-12-2015 | 09:57 AM
  #129
Finally finished my F1 car; well except the wheels and the shell.
I placed the esc in front of the motor, i used a piece of lexan to prop the esc up so it wont touch the t-bar. Thanks to Alan Chow for the suggestion.
Was also able to keep the battery in place with some foam and a battery holder from the kit that you can put in the front.
I am running one of those new sanwa RX-481 receiver that has an internal antenna. It was pretty much the same price as the RX-471.
Old 08-16-2015 | 11:21 PM
  #130
Tried my 102 for the first time today. Car was really good until I hit a board and broke my t-bar. Who knows where I can get spares for this car? Can't seem to find any around. Specifically, 1.5mm tbar and the F Parts arm set.
[RC10TC] is offline
Old 08-17-2015 | 01:27 AM
  #131
Stein Tumert's Avatar
Not sure where you are based...
This company in Germany has all parts in stock.
http://www.modellbau-seidel.de/index...102&mth3=sinfo
Stein Tumert is offline
Old 08-17-2015 | 06:29 AM
  #132
Yes, thatīs a good shop, but t-bars are not in stock. Do the F104 t-bars fit (perhaps with some changes)?
Ronald
Old 08-17-2015 | 09:12 AM
  #133
mtveten's Avatar
The trf102 t-bars are unique to the model.
mtveten is offline
Old 08-18-2015 | 07:09 PM
  #134
HornyToad's Avatar
Having trouble with traction roll.....
Before noon, I needed more power everywhere....stock setup
In the afternoon it was all traction rolls.....��
HornyToad is offline
Old 08-19-2015 | 01:11 AM
  #135
ShadowAu's Avatar
What do you mean by needing more power???
ShadowAu is offline
