newbie, just ordered tamiya ta05 vdf II
#16
You need the tb03d rear hubs. I think they come in 1° toe angles. That is what the ° is. It's how many degrees of toe the hubs give in addition to what you get from the arms. More toe gives more rear stability. For higher drift angles less toe will give you the more intense Drift angles.
#17
You should look into some alternative pulley ratios - overdrive the rear wheels compared to the front.
#18
#19
