Roche Rapide P12 1/12 Competition Car Kit
#182
R/C Tech Elite Member
#183
posted online at - http://www.rochercusa.com/p/set-up-sheets.html
#184
This helps a lot with high traction too.
Inline vs transverse can be debated till the cows come home. I feel an inline reacts quicker and allows for you to stay on-power more. I think it comes down to driving style too. Even though I made A main at big races with my top car I never could be as consistent since it seemed slow to react. I think transverse also works best for mod where you lift and can get more weight transfer in mean time having a car that is more comfortable.
The set up window maybe a little narrower on an inline car that is why spacing out the front end like I do really helps.
Monti
#185
On the Roche front body posts - when mounted they hit the front suspension mounts. What is the deal here?
#187
Thanks man!
What are you using for spacers for the following:
- Front arm track width (the 1.5mm we were just talking about)
- Front ride height (what slide in shims work? Are the Xenons AE bolt pattern?)
- Rear axle block spacers
I know earlier in the thread someone said Xray front ride height shims work so I assume these are fairly standard and just about any brand will work.
I also assume the red .5mm and 1mm shims included in the kit will work for the front track width. I just don't have any to spare currently. I do however have 2mm spacers (I use on my Kyosho ZX5/ZX6 to shorten wheelbase). In your opinion would 2mm be better than no track width increase?
#188
the VBC Lightning front ride height adjusters work fine. spacing is same as associated
#189
I've never used the vbc shims so I don't know what sizes they offer. I like the xray ones cause they have a good size variety and allow for very fine tuning of front ride height
#194
I agree I should be running small tires. At this point however the local track doesn't have big turnouts and I can't justify the tire costs for small weekly club races so I run the tires bigger to start just to get the life out of them so I'm not burning up $25/week just to race 3-4 other guys.
Can you tell me what the spring color codes are for front center and side springs?
Also - I am assuming that the base springs (not in the bonus bag) are all mediums (front/center/side)?
I do see coil counts which is awesome for identification but not completely sure what is being counted as a coil and what isn't in regard to top and bottom.
Last question (for now) - what is the preferred shim for the rear axle height? Front kingpin shims?
Attached is a pic of my fresh build...
#195
In my very scientific testing of the springs (squeezing them with my hand) it looks like the Roche springs follow the same design as others. The ones with the coils closer together are softer, where the ones with the coils farther apart are stiffer.
Don't remember right now which color were which though.
