Like Tree256Likes
Tamiya TRF419
Old 08-23-2018 | 05:20 AM
  #4051
niznai's Avatar
Without making sure there is enough weight transfer to the rear, everything else is as useless as trying to cure pneumonia with flu medicine.
niznai is offline
Old 08-23-2018 | 05:37 AM
  #4052
sosidge's Avatar
That's simply wrong niznai.
Increasing toe in will increase rear grip on corner exit. Diff adjustments will increase rear grip on corner exit. Static camber adjustments will increase rear grip on corner exit. A different body will increase grip on corner exit. None of these depend on weight transfer.
​​​​​​It's all very well being opinionated but at least try and make your opinions accurate.
DaSilva3525 and DRTMI like this.
sosidge is offline
Old 08-23-2018 | 11:41 AM
  #4053
Default C Hubs
I know this has been discussed before but would like to know what chubs you guys are using besides exotec.
TeamThibault is offline
Old 08-23-2018 | 02:08 PM
  #4054
The stock ones are still breaking at carpet tracks? I thought there was a 5 degree Square set out there somewhere.
- Jose
ittjv is offline
Old 08-23-2018 | 09:35 PM
  #4055
Originally Posted by Kelseyrc
Increasing rear toe will make the rear feel more locked in with less chance of breaking loose. Also, lengthening your camber link in the rear will help. You could also try using progressive springs up front, on my XR I am running smj 2.5-3.0 progressives and my car feels a lot more stable through corners.
So the 2.5-3.0 is front? How about your rear springs?
airbiscuit is offline
Old 08-24-2018 | 06:35 AM
  #4056
niznai's Avatar
And of course, weight transfer has nothing to do with grip.
I think you need to read back a few posts and also check the difference between opinion and reality.
niznai is offline
Old 08-24-2018 | 07:54 AM
  #4057
DaSilva3525's Avatar
It does of course, but you were not specific nor offered any other change or direction. Also like mentioned there are many other things that can be changed besides weight transfer.. if you don't want to upset the car if you are happy with how planted it is everywhere else there are so many other things can be done.
DaSilva3525 is offline
Old 08-24-2018 | 07:56 AM
  #4058
Im running x-ray 2.6 in the rear
Kelseyrc is offline
Old 08-24-2018 | 06:52 PM
  #4059
Ah I don't have those xrays. Only SMJs in my tool box.
Old 08-24-2018 | 08:32 PM
  #4060
RAL's Avatar
RAL
Christian Donath seems to be the man with this car in the ETS series. I would look at his setups. SMJ red front and silver rear. Which is progressive 2.5-2.8 front and 3.0 rear. Also seems to run a tad of front arm sweep.
Tamiya TRF419X - Christian Donath - ETS - Trencin - 16-18.06.2017
RAL is offline
Old 08-25-2018 | 11:44 AM
  #4061
niznai's Avatar
The question was asked without any details about the current setup.
Hence I can only leave it to mind readers to make more detailed suggestions.
niznai is offline
Old 08-27-2018 | 04:27 PM
  #4062
Anyone knows where I can get center pulley replacement?
Or can I use any other brands that fits?
Old 08-28-2018 | 05:42 AM
  #4063
nubs's Avatar
You know those last few pages we were talking about parts availability? That one of the parts.
nubs is offline
Old 08-28-2018 | 06:44 AM
  #4064
Unhappy
Damn.
Old 08-28-2018 | 07:59 AM
  #4065
nubs's Avatar
Damn.
I was able to find half the part on ebay from an international seller. You may be able to find the other half through a european distributor. The problem is that a lot of them won't ship to the US.
nubs is offline
