Tamiya TRF419
#1502
Cheers for the info that's interesting to know, we have started using the blacks. On the old diffs the reds were much better than the blacks but we have found the opposite.. maybe they have leaked all out before we run so we don't notice
To be honest I had only a slight leak on the red o-rings so it didn't bother me, but I went over to the black one and haven't noticed any since. I have also changed the shim to a wider (Still 0.3mm) one so that might help.
BTW Ed, do you use the bushings or bearings?
To be honest I had only a slight leak on the red o-rings so it didn't bother me, but I went over to the black one and haven't noticed any since. I have also changed the shim to a wider (Still 0.3mm) one so that might help.BTW Ed, do you use the bushings or bearings?
I've been playing a lot with the diffs recently, and have come back to the kit red o-rings, 0.3mm shims, and a single 0.1mm 5mm shim behind the o-ring in the case. Seems best compromise between seepage and freeness.
The Xray o-rings sound interesting though... might have to give them a try.
#1505
#1510
Did you match up the two sides? There is a locating marker on both and it slides together easily.
If that is ok then check that you assembled the internals correctly and that everything is seated properly before you close the two halves together. There is no way that you should have a gap like that.
#1512
That's not a problem, if the diff is not crunchy. It only means the two halves are kept away by the gasket. If yo want to check just pull out the gasket and reassemble the diff. Any gap left now?
A number of problems might be responsible for the leak here. The screws are not tight enough, the diff halves' mating faces are not flat, the gasket doesn't sit correctly, or it wasn't soaked in oil, etc. Try doing up the screws again. Back them off a bit and re-tighten.
#1513
Chris, as mentioned above, the cases only go together one way.
You have to check for the alignment marks on the diff halves, instructions do show where to look but you have to know where to look in the instructions.
It's not printed in super bold type, maybe it should be.
#1514
I also mark the bearing holders in the bulkhead (the little arrow) with a silver Sharpie to easily be able to know I've got both bearing holders matched up when I'm adjusting the belts.
256Likes
