SpeedMerchant World GT4
#46
Traction roll is gone.
Next!
We went from 17.5 to 13.5 at our track. It's a huge track. I dropped in a D4 1S I had laying around and it seemed all right. Apparently I'm losing about .6 a lap with it though. I'm going to to try a Fantom FR-1 13.5 RS. I do have a nearly new Reedy at hand to try, just have to pull it from another car. Or should I find a new horse for this ride?
Next!
#47
Hi Guys,
Hope everyone is doing well.
For those of you have have lost your World GT foam class at your local track, or World GT-R hasn't taken off, or isn't your cup of tea. I've put together a cool, easy to do conversion to turn your GT4's and 4-R's into RoadKill 10's.
If you haven't seen them go, Pro 10/235mm cars drive very easy and really hustle around a track. They are quickly picking up steam on the racing circuit, and they will be a featured class at Vegas, Cleveland and the Birds this upcoming season.
Here's a link to the conversions...
http://www.teamspeedmerchant.com/news.html
and check out the RoadKill 10 thread for more info and some links to videos.
http://www.rctech.net/forum/electric...10-pancar.html
Have a great day.-Bruce
#53
Weird - Bruce has been no longer than about 12hrs in responding to my emails when I've had questions both before and after the sale within the last few weeks.
Thanks for the info about the measurements. Seems the MX Stang body might be a tight fit up front. I'll give it a try though.
#54
Are you using [email protected] to contact Bruce???
idbdoug
#55
My original email went to the sales@ address, but the reply and all communication afterwards have been from [email protected].
#56
Hey liljohn - still running the same setup you were on page 3 of this thread? Just starting to build my car and I was thinking of starting with your setup, but with little to no droop in the rear since my track is as smooth as it can be. I have the .018, .019, and .020 springs. Just curious if you stuck with the settings you had listed or if you changed something like the front springs to help with the traction rolling.
#57
#59
I have a bit of an odd (and potentially dumb) question. My servo finally arrived last night (pretty basic S9650). The chassis is drilled/countersunk for the included servo mounts in four places - right or left align on the servo I would assume. All four holes on the plastic mounts don't match with the ears on the servo. That's no problem - one screw on each side should be fine anyway. The problem is the width. When the plastic mounts are attached to the frame, they're too close together to get the servo in place. Although I didn't measure, I'm guessing the servo body is around 1/16" - 1/8" too wide. Am I doing something wrong here?
#60
