Advance R/C Car R10 2015 >
Old 09-22-2014, 06:40 PM
  #256
Originally Posted by Josh-n-ya
You can use part# R102507 on the front of the motor mount to replace the one that gets in the way of pinions.
http://www.shopviperrc.com/ProductDe...ctCode=R102507
but i use that post for chassis flex adjustment lol. i dont use anything bigger than a 52 pinion anyway. lol.
dragonracing is offline
Old 09-22-2014, 10:37 PM
  #257
Josh-n-ya's Avatar
Trader Rating: 95 (100%+)
that's fine. Its just another option. Im bummed my black edition is still on back order. Been waiting about two weeks now and was told its going to be another week.
Josh-n-ya is offline
Old 09-23-2014, 12:30 AM
  #258
That sucks man. I'm building my second one that I'm probably not even going to race now...damn job. How many more are coming?
Carnage9270 is offline
Old 09-23-2014, 01:36 PM
  #259
Professor's Avatar
quote= You can use part# R102507 on the front of the motor mount to replace the one that gets in the way of pinions.
if you use the above part from the 2013 to allow for larger pinions,you may also have to dremel out the top deck to accomodate the larger pinions
Professor is offline
Old 09-23-2014, 02:29 PM
  #260
Suspended
Whats a good asphalt set up for this car. Or where could i find one for 17.5.
nene_805 is offline
Old 09-23-2014, 03:05 PM
  #261
Check out ARC Driver on Facebook. Setups get posted there.
barnacle is offline
Old 09-23-2014, 04:57 PM
  #262
Suspended
Ok thanks man
nene_805 is offline
Old 09-23-2014, 05:00 PM
  #263
nikos2002's Avatar
Trader Rating: 30 (100%+)
Not many -- hence the "limited edition" part of the name.
They have all (by all I mean less than 10) been sold to customers or hobby shops/. Those hobby shops will have them for sale when they are delivered.
nikos2002 is offline
Old 09-23-2014, 06:07 PM
  #264
stiltskin's Avatar
Trader Rating: 103 (100%+)
I got mine. Awesome car.
stiltskin is offline
Old 09-23-2014, 06:35 PM
  #265
Trader Rating: 15 (100%+)
Petitrc.com has many arc setups for asphalt and carpet.
trigger is offline
Old 09-23-2014, 08:56 PM
  #266
The box stock setup is a really good starting point. A few quick changes I'd recommend are.
-Losi 35 shock oil F/R
-3-5k rear diff oil
-HPI Silver springs F/R
-1-2mm on the ackerman spacer (Layout and tires will make this a big change)
-Drilled shock caps with zero to 20% rebound
Use a Blitz GSF or PF LTC-R and you should be really close!
Kody
Kody is offline
Old 09-26-2014, 12:51 AM
  #267
Suspended
Can i use a standard size servo with this car?
nene_805 is offline
Old 09-26-2014, 02:49 AM
  #268
you can, but depending on the size of your receiver and esc, you may need to put the receiver on top of the servo. The use of a low-profile servo has become standard for TC.
inpuressa is offline
Old 09-26-2014, 08:48 AM
  #269
For those of you not on da Facebooks...(From Arc Driver)
Here's the 17.5 Blinky carpet setup that Kody Knudtson has been driving our last couple of nights out. It seems to be working really well. Car is very predictable and easy to drive. Another great starting point for da rug.
Advance R/C Car R10 2015-carpetsetup.jpg
Old 09-26-2014, 08:58 AM
  #270
-3-5k rear diff oil
Kody
A little birdy told me there's another Black Edition available from this guy, Pre built. A pre built car from the Carpet Nationals champion? Why did I already buy 2 cars? WHY?!?!?!
