Tamiya TB Evo 6
#1443
#1448
The aluminum chassis looks great. Hard to justify getting one since my both my cars are pretty dialed in right now. I don't want to have to start over chasing set-ups.
On another note, both my cars have slightly different set-ups on them (USGT & USGT). But both cars exhibit hard initial turn in if I'm not carful. What are some general set-up ideas I can try to lessen this. I can say both cars already have 0deg front tow in. I really like haw well the car handles other than that so I don't want to really change too much.
#1449
Recommend changes in this order
Front shock pos 8 (Slower initial roll, more stable)
Raise front inner camber link (less camber gain)
Raise front camber link inner and outer (Less aggressive front)
#1450
Thanks. I'm running RSD springs similar in rate to the yok's. On the USVTA car, the one with more aggressive turn in, the front camber links are at the longest position as it is now, and the USGT are in hole 3. Both already have pretty low front roll centers, but I'll give a go in .5mm increments to sailing the inner front camber link. ill also try moving the front shock out a couple more holes
#1452
Thank you to those of you how helped me add another Exo 6 to my RC garage. The new one will become my VTA car. As much as I like my years of VBC cars, the Exo 6 is simply awesome to drive. This is my chassis for the foreseeable future. Great support network of fellow racers as well.
#1453
Front roll center adjustments that were suggested as well as droop on both ends are what I usually start with when trying to calm down the front end of the car.
Also, I know it all comes down to preference, but I tend to remove steering servo speed and adjust my steering expo to be a little slow to counter-act my nerves. Sometimes my hands shake so bad in the mains that if I didn't have my Expo adjusted, my car couldn't possibly go straight, ha!
#1454
How does the back end of your car feel? Could it be the back end being too loose and causing the feel of too much initial turn in?
#1455
A version 2 Evo is on the way from Tamiya
84427 TB EVO 6 Ver.II Chassis Kit
interested to see what this entails
