Tamiya TB Evo 6
#601
To Metalnut: Thanks!!
#602
For the top case fitment issues a little grind will do wonders!
http://www.rctech.net/forum/13489166-post838.html
#604
#605
Can anybody recommend which 48 pitch spur gear and pinion they are using successfully for their Evo6 in 17.5 and 21.5? Not 64p or o6 module. Thanks.
#606
#607
Why not?
Please explain your theory, don't just make a statement like that. Doesn't help anyone.
#608
The 39T bevel gear or TB EVO 5 One-Way gear is a direct fit.
Never had a problem driving 13.5 Boosted 12T(Tamiya) or even 6.5T with the Evo 5.
Andre
#609
Andre
#610
#612
In fact the the biggest pinion is 45 and smallest spur is 65, therefore your fdr should be 3.61.
Do you understand?
#613
#614
I did something along those lines, though I like that method more I think. But that won't help the fact that the top case rocks side to side and then binds the diff bearings when screwed down. I'm tempted to sand the top case flat (sand paper on a setup board), but that would technically squish the bearings even more. So, I'm currently using two 0.1mm shims on the rear two screw holes (opposite input shaft), in essence propping the case up on one side to let the diff bearings breathe. I think it's helping... maybe
#615
Grinding the hole for the smaller 10mm bearing cured the case rocking side to side? That seems odd to me, as my rock on their own with no bearings or anything inside. In fact, I think they rock on the edge opposite the input shaft, that is the edge I ground down in one of them to make them fit right. It's just difficult to tell what makes the gear diff (side) bearings bind when the case is screwed down.
