Tamiya TB Evo 6
#376
Spurs:
http://www.teamcrc.com/store/index.p...&cPath=1_46_50
Pinions:
http://www.teamcrc.com/store/index.p...ort=20a&page=4
What's not to love?
Pinions:
What's not to love?
Any know if robinsons fit ?
#377
Still sitting in the box(es). I sanded all the graphite, but then company showed up last week and I got "evicted" from my office, aka the spare bedroom. Be a couple more weeks before I can get them built, maybe two months before I can go to TQ and test, and IIC isn't till October
Rod (or, anybody with a Evo6 and a 418 around in the same place and the same time):
Can the 418 servo mount be cross fitted into the EVO as a bolt on?
#378
Found a vid for those of you that want to see the Evo6 in action. At pole.
+ YouTube Video | |
#379
As for why my car was so loud...I'm still not sure. I finished rebuilding the car and took a look inside the gear boxes and found no wear on any of the gears. The boxes themselves are pretty quiet. I think the culprit may be my center miter gears. I've been using a dry lube (a spray that dries to a teflon/fluorine finish) and coupled with a slight wobble in the miter gears, causes some noise. Additionally, I run just about everything dry with no grease. The result speaks for itself As a reality test, I gooped on a bunch of grease everywhere and the noise improved dramatically. I'm not a fan of grease flinging cars, so I cleaned everything off with motorspray and added some waxy lube on top of the dry lube for the miter gears, as well as maxima chain lube on the shafts and it has gotten a touch quieter. I'll figure it out eventually.
I don't know and didn't really measure. The Evo servo mount is alright. I took my time, making sure that everything in the assemble looked nice and straight, before I torqued the crap out of the screws.
#380
Pretty sure other servo mounts won't bolt on because the Evo.6 servo mount is offset to clear the shaft running down the middle.
#382
For the most part, the Evo 6 feels good. On our track, it can use a touch more turn in, and have a little less dumping over in the esses. I ran the 418 and Evo back to back with 13.5 motors. Unfortunately, the lap timer was not turned on for the 418 runs so it's difficult to say which is better. The 418 has been pretty quick lately so that says a lot. When I ran 17.5 later in the day, it was easy to drive and was able to put in decent lap times. For reference, a sub 14 second lap is above average to good. Mid 13's is really good...and low 13's is wishful thinking but not out of the question
#383
Started building mine yesterday.
There is a lot of room in all directions for all kinds of spur/piniong combinations. I had some Kawada spurs in the box. They fit just fine :-)
#384
#385
Has anyone quantified how much the servo mount might shift in a crash and how that affects trim setting? I was thinking it might be worthwhile to countersink the servo mount CF arm and use countersunk head screws instead of the kit button head screws. The countersunk screws and holes should stay centered better than kit design.
#386
Where is the best place to get parts for the Evo 6??
#387
Just arrived
In reading Kentech's blog it seemed his only change to the kit build was to swap a couple bearings for some included bushings in the diffs. Are most of you building the car right from the box? Anything I should add or change on the car?
Can't wait to start the build. Thanks.
#388
Here it is my finished EVO 6 and my first Setup Sheet and Outdoor run
