Tamiya TB Evo 6
#2341
I have multiple Exo 6's. I run them in VTA and USGT.
Very good stock class chassis. Incredibly free drivetrain with excellent aftermarket support from Exotek as well as OEM Tamiya options.
#2342
#2343
BEST POST IN THIS THREAD !!!
Now I can also use these damper stays in my tc4 to support the tc7.1 super short shocks: I guess I must thank you guys for the support...
THANK YOU !!!!!!!!!!
New short carbon fiber shock towers for the use of TRF419x super short shocks are now available.
http://www.tamiyausa.com/items/radio...stay-set-47327
#2344
what do you guys recommend for spur gears replacements?
#2347
Mike, if running 48p gears, what size pinion and spur are you running? I can do the math to get a comparable ratio, but I don't know what matches diameter wise. Example. I currently run a 78/49 64p ratio. A 48/30 48p gives the same ratio, but are the gears (particularly the spur) the same size?
#2348
#2349
I should look into making some 57 tooth as that seems that could be the best for both 21.5 and 17.5 gearing.
#2354
Nice decals.... If you can see it as good as a bright colored car, you're probably not going fast enough to Tq and win... Let us know when you switch to a brighter color scheme for the win....
