Is there really a difference? (Bodies)
Hey,
After almost 2 months of driving the included SKODA body on my JRX-S, I'm looking for a new body; not because I don't like the SKODA anymore, but because it was the only body I used and it's kinda beat up.
I'm not a beginner, but I'm definitely not a pro either.
I know some people say that they can FEEL the difference btw bodies (and I'm not talking about the difference between a HUMMER body and a Stratus-I can feel that...lol, I'm talking about the ones listed below), but before I buy one, I would like to get an honest answer:
Can you really feel the difference between a Parma Alfa, Dodge Stratus 3.0C, and Mazda 6, if so...which one's the best for what I'm doing?
BTW, I'm racing STOCK, FOAMS on CARPET.
Thanks!
Thanks!
Yes, there really is a big difference. I'm not a carpet racer but I've always heard that the Parma Alpha in the one to run for foam on carpet.
A good example was a couple weekes ago. During practice I had the car working fairly well with the Ride Honda Accord. Just a little pushey. I wanted to try the Yokomo Stratus E body. I pulled it off after two laps with that body it was so tail happy. It took the car from being on the tight side to uncontrollably loose. I put the Ride body back on and went right back out and right back to being a little tight. So yes, there is a noticable difference between bodies.
I race carpet only (one of the only carpet-only racers in CA) and I found in foam 19t and Mod the body to run is the Parma Alfa. A couple of my pals are telling me to try the Cadillac but I don't think it'll touch the Alfa.
I would imagine carpet is less noticable between bodies than asphalt. Just due to the low traction and naturally higher speeds on asphalt.
The Proto-form Strat 3.0 Carpet version and Alfa 2.0 are more balanced and work well on carpet but they weigh ~10% more than the Parma body and that is all high weight that really effects the car's CG. I didn't believe this until I weighed bodies back to back for myself.
I really prefer the looks of the Proto-form bodies and that is all I will ever use on asphalt or carpet with rubber tires but on foam tires the Parma is the way to go.
Originally Posted by BrainTeased
whats the weight difference may i ask?
HiH
Ed
Originally Posted by AdrianM
Actually its quite noticeable on carpet. The Proto-form Mazda 6' and Strat 3.0 are awesome on asphalt for the massive down force and steering they produce. On carpet these traits yield a car that is glued to the track and very inefficient/hard to drive.
Of course if your prone to hitting things and drastically changing the body downforce, then this may not be a good idea.
Body Weights:
Parma Alfa: 102g Stickered RTR
Yokomo Type E: 104g Stickered RTR
Proto Alfa 2.0: 108g w/o Decals
Proto Alfa 2.0: 99g Almost see through, one color silver practice body w/o Decals
Proto Mazda 6: 112g Stickered RTR
All the same painter except the Practice Alfa and the Yok. The Yok actually has a lot of paint on it!
This is interesting as you can see what intricate paint jobs and decals can do for the weight of a body. Apples to apples though the Protoform bodies are a little heavier...10G on average.
For Foam tire Carpet this is a big deal but for Asphalt its not at all an issue. The aerodynamics of the Protoform bodies are so superior that you pretty much need a Mazda 6 or Stratus 3.0AP to be competitive at high level Carpet or Asphalt rubber tire racing.
