Old 07-28-2005, 08:00 PM   #1
tc3blue's Avatar
Default Is there really a difference? (Bodies)
Hey,
After almost 2 months of driving the included SKODA body on my JRX-S, I'm looking for a new body; not because I don't like the SKODA anymore, but because it was the only body I used and it's kinda beat up.
I'm not a beginner, but I'm definitely not a pro either.
I know some people say that they can FEEL the difference btw bodies (and I'm not talking about the difference between a HUMMER body and a Stratus-I can feel that...lol, I'm talking about the ones listed below), but before I buy one, I would like to get an honest answer:
Can you really feel the difference between a Parma Alfa, Dodge Stratus 3.0C, and Mazda 6, if so...which one's the best for what I'm doing?
BTW, I'm racing STOCK, FOAMS on CARPET.
Thanks!
tc3blue is offline   Reply With Quote
Old 07-28-2005, 08:04 PM   #2
ALBERTO's Avatar
Trader Rating: 23 (96%+)
Send a message via AIM to ALBERTO Send a message via Yahoo to ALBERTO
the parma alfa is my personal favorate.. and tha stratus 3.0 is my next favorate.. I too race on carpert
still fishing
ALBERTO is offline   Reply With Quote
Old 07-28-2005, 10:11 PM   #3
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Yes, there really is a big difference. I'm not a carpet racer but I've always heard that the Parma Alpha in the one to run for foam on carpet.
A good example was a couple weekes ago. During practice I had the car working fairly well with the Ride Honda Accord. Just a little pushey. I wanted to try the Yokomo Stratus E body. I pulled it off after two laps with that body it was so tail happy. It took the car from being on the tight side to uncontrollably loose. I put the Ride body back on and went right back out and right back to being a little tight. So yes, there is a noticable difference between bodies.
Jon Kerr is offline   Reply With Quote
Old 07-28-2005, 10:17 PM   #4
BlackKat's Avatar
I race carpet only (one of the only carpet-only racers in CA) and I found in foam 19t and Mod the body to run is the Parma Alfa. A couple of my pals are telling me to try the Cadillac but I don't think it'll touch the Alfa.
BlackKat is offline   Reply With Quote
Old 07-28-2005, 10:22 PM   #5
AdrianM's Avatar
For foam the only way to go is Parma Alfa
Adrian Martinez
Old 07-28-2005, 10:41 PM   #6
ChadCapece's Avatar
I would imagine carpet is less noticable between bodies than asphalt. Just due to the low traction and naturally higher speeds on asphalt.
ChadCapece is offline   Reply With Quote
Old 07-28-2005, 10:49 PM   #7
AdrianM's Avatar
Actually its quite noticeable on carpet. The Proto-form Mazda 6' and Strat 3.0 are awesome on asphalt for the massive down force and steering they produce. On carpet these traits yield a car that is glued to the track and very inefficient/hard to drive.
The Proto-form Strat 3.0 Carpet version and Alfa 2.0 are more balanced and work well on carpet but they weigh ~10% more than the Parma body and that is all high weight that really effects the car's CG. I didn't believe this until I weighed bodies back to back for myself.
I really prefer the looks of the Proto-form bodies and that is all I will ever use on asphalt or carpet with rubber tires but on foam tires the Parma is the way to go.
Adrian Martinez
Old 07-28-2005, 11:02 PM   #8
Jon Kerr's Avatar
I couldn't belive the weight difference between the Ride body and the Proto bodies.
Old 07-29-2005, 03:42 AM   #9
BrainTeased's Avatar
whats the weight difference may i ask?
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 07-29-2005, 06:37 AM   #10
TryHard's Avatar
About 10g or so, at least thats what I got when I weighed my mazda6 back to back with my Ride Stratus. (and there is now difference in paint scheme, so that would only account for a small amount). The ride deffiently uses thinner lexan in some places though.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 07-29-2005, 07:00 AM   #11
teamgp's Avatar
This is true. But if your running foams on carpet, then the rules normally allow any shore rating which gives you a wide variety of grip choice. What I've done is used the Mazda 6 in conjunction with harder compound tires that provide less grip, especially in the front. The advantages are a longer life for the tires and less chunking.
Of course if your prone to hitting things and drastically changing the body downforce, then this may not be a good idea.
teamgp is offline   Reply With Quote
Old 07-29-2005, 07:47 AM   #12
Jon Kerr's Avatar
About 11 grams. Same painter doing the same paint scheme so the amount of paint should be the same.
Old 07-29-2005, 08:14 AM   #13
AdrianM's Avatar
Body Weights:
Parma Alfa: 102g Stickered RTR
Yokomo Type E: 104g Stickered RTR
Proto Alfa 2.0: 108g w/o Decals
Proto Alfa 2.0: 99g Almost see through, one color silver practice body w/o Decals
Proto Mazda 6: 112g Stickered RTR
All the same painter except the Practice Alfa and the Yok. The Yok actually has a lot of paint on it!
This is interesting as you can see what intricate paint jobs and decals can do for the weight of a body. Apples to apples though the Protoform bodies are a little heavier...10G on average.
For Foam tire Carpet this is a big deal but for Asphalt its not at all an issue. The aerodynamics of the Protoform bodies are so superior that you pretty much need a Mazda 6 or Stratus 3.0AP to be competitive at high level Carpet or Asphalt rubber tire racing.
Adrian Martinez
Old 07-29-2005, 08:27 AM   #14
tc3blue's Avatar
Wow, lots of comments!
Thanks a lot!
My next carpet/foam tire body: PARMA ALFA
DX2.0 or DX3.0 is there a difference? ghj1997 Electric Off-Road 7 08-26-2008 08:13 PM
How do you tell the difference bvoltz Rookie Zone 1 06-07-2006 01:24 PM
What's the difference in the car bodies? jigga21 Electric On-Road 1 11-15-2004 10:29 PM
What's the difference? DocSafety Nitro On-Road 0 04-06-2004 10:11 PM
Rare Pan Car Bodies 1/10 1/12, Yok Mini BOdies, Losi Bodies Etc dynamic_e R/C Items: For Sale/Trade 3 07-31-2003 09:39 PM
