Team Associated TC6.2 Touring Car
#616
When grip is crazy, i use 450cst in rear 400cst front and yoko blue spring rear and black in front.
Piston number 2
That's all
#618
#621
#625
Neither have I but thats a good idea as long as it doesnt affect the performance of the dcv just incase you break or something might hold together better
#628
do these fit the 6.2 shocks?
http://www.amainhobbies.com/product_...tion-X-Rings-8
and when using the rsd bladders do i still need to drill the hole in the cap? also, does anyone have a nice hinge pin set for the car? all i see is the lunsford with turn buckles. i figured ae would have some gold ones
#630
When building your shock, instead of pressing the rod end in all the way, compress it about 2/3 of the way. It will also depend on what bladder you use. To get exactly 60% you would have to measure the fully extended shock shaft, and figure out what 60% would be
