Xray X1 - Formula One Car >
Like Tree305Likes
Old 04-20-2016, 09:31 AM
  #1411
R/C Tech Elite Member
JayL's Avatar
yes, I run the lrp 2900 lcg. I also run a 25g steel plate under it, then my car is 1010g
car works great this way just feels more responsive, not more nervous. I prefer the lcg battery for a track layout with many chicanes, of course I then have to add 40g, and I do, 20g on the rear of the pod and 20g near servo, our rules are 1050g
I do run the battery sideways as well.
Are you running it inline? I could see it being nervous that way
JayL is offline
Old 04-20-2016, 10:44 AM
  #1412
Hi,
I've bought a useg X1 '16 and I have a qustion about the damper piston.
I'm looking for the 1,3 mm 3 hole piston. The kit piston's are marked 1.0, 1.1 and 1,2 do I need to drill the holes up to 1.3 or where can I find that one?
Thank's for any help.
Claude
toroloco is offline
Old 04-21-2016, 03:14 PM
  #1413
yumlailai's Avatar
I am new to this class, if I have a chassis tweak, what should I look at first? I have put my X1 15 on the tweak bar and seems like the front end is slightly tweaked. I have have an accident with my car (because I just ran 2 packs of batteries and the car couldn't go straight). The car tents to oversteer on right hand turn.
What is the first thing I should look at to solve my problem?
Thank you
yumlailai is offline
Old 04-21-2016, 03:22 PM
  #1414
Location: El Pueblo de Nuestra Señora La Reina de Los Ángeles del Río de Porciúncula, California, Unites States of America
Trader Rating: 40 (100%+)
Common problem. Loosen the bottom front end screws and re-tighten them.
lagcisco is offline
Old 04-21-2016, 04:30 PM
  #1415
yumlailai's Avatar
Thank you sir
Old 04-21-2016, 04:31 PM
  #1416
yumlailai's Avatar
What spur gear should I use if I'm running 21.5, I have the stock 96T right now, but guys from our track is running 90 or 88 on their VBC
Old 04-21-2016, 06:42 PM
  #1417
JoeyE's Avatar
Trader Rating: 45 (100%+)
What part number are the kit springs for front and side for 2016?
JoeyE is offline
Old 04-21-2016, 09:12 PM
  #1418
nova2015's Avatar
Battery is running sideways, with ESC and RX in front of it. Running weight is 1035g, on Ride XR tyres. Next run was with 4300 shorty pack, and car felt solid again.
nova2015 is offline
Old 04-21-2016, 09:57 PM
  #1419
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
You have to compensate by running softer side springs with the LCG pack. With that said, I still prefer running the regular shorty pack.
Dan is offline
Old 04-21-2016, 11:42 PM
  #1420
sbd
May I add, you need to use a softer center spring and softer center shock oil.
I am using only the lcg bateries which are about 65-70 g lighter than standard shorties. The car is nimble and once you soften the back end it is not nervous at all. Also it seems to me it responses better (more sensitive) to tuning adjustments. BTW my car is at 980 g with Ride XR tires and 960g with Pits.
sbd is offline
Old 04-22-2016, 04:49 AM
  #1421
It all depends on your Track size that you run on for the FDR. Most of the folks who went to smaller spur gears do so for the reason of moving the motor away from the rear wing. With the larger 96 gear when you roll over or have a wreck the rear wing will most likely contact the spur and bur the spur which will then affect gear mesh and you'll end up stripping the spur in short order. Ive gone down to a 90 and 92 and also made a little notch in the rear wing where it would clear the spur if and when contact could happen.
freebird is offline
Old 04-22-2016, 09:57 AM
  #1422
1spunspur's Avatar
That's called a spun spur.
1spunspur is offline
Old 04-22-2016, 01:38 PM
  #1423
you are correct sir........ You get the prize
freebird is offline
Old 04-22-2016, 04:09 PM
  #1424
nova2015's Avatar
Mine is currently running stock springs and oil, so sounds like I need to pick up some soft springs and go to a lower oil, perhaps 350/400 be a starting point.
nova2015 is offline
Old 04-23-2016, 05:13 AM
  #1425
j.d.roost's Avatar
Trader Rating: 32 (100%+)
Default Roll center
Can somebody explain how the front roll center adjustment works?
I understand the shims change it...but what does adding and removing the shim thickness do to the suspension and to the grip level of the front?
Does is work like tc ...thicker lower arm shim should...in theory raise the roll center (increasing grip)?
Also can I lower the r.c. by adding shims under the front arms?
Can I also add reactive castor by adding offset shims to the upper arm?
j.d.roost is offline
