Xray X1 - Formula One Car
#2911
So I finally had a failure on the super durable Xray X1 gear diff after owning it for a year. Looks like the shaft had a cycle fatigue failure. If you notice that your right rear wheel is loose or has a little camber on it, yours too could be failing like this. You can easily inspect the shaft when doing a oil change and if you see a hairline crack, its done and should be replaced. The biggest tell tale sign is that you suddenly get a loose gear strip type feeling while driving but the gears don't actually strip
#2912
Yikes, do you recall if your gear diff was a V1 or V2? I know they made some changes to the shaft between the two versions.
#2913
#2914
https://www.youtube.com/watch?v=6IzG...Dp-CbO-y9xykbM
The X12 video gives us an idea of the new X1. New Roche like rear pod, ride height back to pills, and maybe a new front end and side links.
#2915
#2917
can those few things be “upgraded” on the ‘19 from the ‘20? I’ve never driven F1 and I’m doing my research on various chassis and what not.
#2922
Looks like the new X1’21 is using the same body profile again, not much info on it yet, but speculating that its going to use the new X12’21 center pivot
#2923
honestly, I would not sweat all that much on what year car to get. I have a 2016 chassis, and I was able to go consistently faster then the '19 and '20 chassis, simply because I was able to setup this chassis better for that specific condition. I also bought this chassis used, so there is a LOT of mileage on it, but still it works great. Unless you go Snowbirds A final top 5 or ETS top 5, there will be very small change due to the new chassis. In fact, the 2020 model with all of those setup options, just complicates the finding of the optimal setup.
#2924
'21
Surprised there hasn't been any conversations about this today.........
Xray X1’21 1/10th Formula chassis - Red RC
#2925
Another year, another car with not much innovation. XRAY making money....
