Xray X1 - Formula One Car >
Like Tree305Likes
Old 01-08-2015, 07:05 AM
  #421
Originally Posted by Fran
Do you think Hudy will make the correct threaded inserts to use on their pancar setup station now that they have a F1 car?
There's no real need to setup camber since it's adjusted with the inserts and for toe you can just use 3 wheel bearings and the tc setup station.
So i think they might offer some kind of adapter bushing to the tc setup station similar to what they did for the XB4 rear axles.
niemand is offline
Old 01-08-2015, 11:01 AM
  #422
Originally Posted by JoJo1241
that is shoegoo, a bit discoloured.
I have put a thin layer of it on the side walls of the rear tires to prevent them from damage.
Rubber tire glue & Hudy body repair can also be used.
Highly likely that Hudy will come with specific tools now that xray/hudy has an F1 car. If you have the car, why not sell specific tools for it.
Thaan is offline
Old 01-08-2015, 11:54 AM
  #423
Pretty sure Hudy body repair and shoe goo is the same.
Why not use CA glue?
niemand is offline
Old 01-08-2015, 12:52 PM
  #424
Trader Rating: 38 (100%+)
CA gets brittle and hard, rubber and shoe goo stays a more flexible.
chensleyrc1 is offline
Old 01-09-2015, 02:14 PM
  #425
Trader Rating: 23 (100%+)
What servos does the X1 take? If im using a standard S9551 or BLS551 will this be okay?
Zhangesh is offline
Old 01-09-2015, 02:40 PM
  #426
xrayracer1's Avatar
As long as it is a low profile servo you will be fine.
xrayracer1 is offline
Old 01-09-2015, 03:48 PM
  #427
jlfx car audio's Avatar
Trader Rating: 37 (100%+)
So what wing are you guys using? Anyone have traction role issues? If so what did you do to prevent it on a high bite track?
jlfx car audio is offline
Old 01-09-2015, 05:02 PM
  #428
Evo 13's Avatar
I have the s9551 and it fits fine
Evo 13 is offline
Old 01-10-2015, 05:32 AM
  #429
evostyle's Avatar
Trader Rating: 103 (98%+)
Will the stock Tamiya front wings bolt on?
evostyle is offline
Old 01-10-2015, 05:50 AM
  #430
JoJo1241's Avatar
Tamiya front wings can be bolted right on , it is a direct fit.
It will need some trimming on the body, and you have to make the front body post longer.
Attached Thumbnails Xray X1 - Formula One Car-spoiler1.jpg   Xray X1 - Formula One Car-spoiler.jpg
JoJo1241 is offline
Old 01-10-2015, 07:53 AM
  #431
evostyle's Avatar
Awesome! Thank you.
evostyle is offline
Old 01-10-2015, 10:06 AM
  #432
JoJo1241's Avatar
I assume this is for rubber tires.
Less camber, harder front tires, CA glue on the side walls of front tires.
And of course, go as low with ride height as is permitted.
As for wings, the stock one in the rear.
In the front, also the stock, or any Tamiya wing, then you may need to trim the front of the body, and possible relocate the body post.
JoJo1241 is offline
Old 01-10-2015, 03:17 PM
  #433
I made a Tamiya F1 Type M body fit to my X1.
JanTRF is offline
Old 01-11-2015, 09:27 AM
  #434
Hi to all,
I'm X1 owner also,a question for you...
Can you adjust the height of your CAR the same front and rear?
Thks
Pigio
Pigiolino is offline
Old 01-11-2015, 10:21 AM
  #435
TENCHO's Avatar
does the rear pod hit the body under actuation? looks like a tight fit...
TENCHO is offline
