Xray X1 - Formula One Car
#2131
Aluminum flex or full aluminum chassis for sure. Get yourself some 2.5 front springs to replace the 3.5.
Gear diff is preference. I have found myself to be quicker with a gear diff on carpet personally. But I know people who prefer ball diff.
#2132
Inline or across?
#2134
Ill be 17 car, gravity rc wheels and tires, 25.5 motiv, etc etc.
#2136
Received my Fenix X1 chassis and pod for my '17 from CRC. In case anyone was wondering, there is a very tiny chamfer on both the edges of both the top and bottom, which the X-ray aluminum chassis doesn't have. For the milled sides, it is not a chamfer, but a stepped milling. 0.15mm has been milled from the sides, not much at all. The chassis is also slightly narrower by about 2mm on each sides of the widest point.
Little stiffer than the option Xray X1 flex chassis but of course, not as stiff as the full aluminum X1 chassis.
Overall, a very nicely machined product and a little more affrodable than the X-ray brand option. Works on the 15/16 cars too. Carpet season needs to start sooner so I could test it out.
#2137
I think it is time to change the fossil rules. F1 should be the faster class in the real racing. But in the RC world we even cannot accept a camber and tow in the rear. IS it a JOKE?
#2138
speaking from experience, if you break the lower arms, might as well check the servo stand for any tweaks
#2139
Do most perfer solid or flex aluminum on black crc carpet?
#2140
I am looking for tires that work on asphalt (fine surface).
The temperature here in Sweden is usually not so high.
Now i have been testing with a indoor Ride tire (F1 ETS RIDE) The grip is not good.
Mike
Mike
#2142
The ride GR tires will work perfectly well given the car setup is right. These seem to be much better compared to the XR.
#2145
on black carpet 21.5...are yall running a soft spring setup w/ like 10-20k tube lube?
