New Novak Brusless System >
Old 07-09-2007, 02:01 PM
  #2371
mazmo's Avatar
Originally Posted by Marcos.J
if i recall i had my cyclone geared around a 4.4fdr
I usally use 4.67 to 4.80 on a fairly small track.
mazmo is offline
Old 07-09-2007, 02:03 PM
  #2372
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
sounds about right
Marcos.J is offline
Old 07-09-2007, 02:06 PM
  #2373
mazmo's Avatar
sounds about right
Thanks marcos ..I'm off to work now
mazmo is offline
Old 07-09-2007, 05:00 PM
  #2374
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Originally Posted by VooDooPH
is there supposed to be fore-aft play in the rotor? i replaced my rotor with a sintered one but the old rotor didn't seem to have any shims with it. now, after placing the sintered rotor, i can feel quite a bit of play when i pull on it.
found a round paper washer that looks similar to the paper rings at the top part but i can't seem to find a place for it in the motor.
bump
VooDooPH is offline
Old 07-09-2007, 07:20 PM
  #2375
I just ran my 13.5 BL sintered motor this past weekend with a FDR of 4.5. I had great acceleration down the straight - this is on a parking lot track. The only issue that I had was when I slowed down going into a turn I lacked a lot of torque coming out of the turn. Do you think I should gear up to 4.0 or should I gear down more to 5.0? This is a pretty small parking lot track.
Thanks!
home13oy75 is offline
Old 07-09-2007, 08:41 PM
  #2376
STLNLST's Avatar
Trader Rating: 32 (100%+)
Thanks!
going to 4.0 will give you even less punch out of the turns. Going to the 5.0 will give you the bottom end grunt that you are looking for.
STLNLST is offline
Old 07-09-2007, 08:45 PM
  #2377
STLNLST's Avatar
MarcosJ- Are you running the spread spektrum or the regular GTB (1st generation) The reason i ask is because the gearing you are suggesting. I can run that gearing with the first GTB but not the spread spektrum. I find myself gearing down to get the same out of the motor. My 4.5 loves a good 8.6 FDR with the first GTB but that same motor with the spread spektrum loves 9.66 Is this the case with your speedo's? Also....what should I look to gear a 5.5 at? I'm going to run one for the first time tomorrow for practice at the nats.
STLNLST is offline
Old 07-09-2007, 08:48 PM
  #2378
Super Moderator
Marcos.J's Avatar
well my speedo was the GTB (regular) but now since i've been running 5 cells im using the T-spec (weighs than the GTB)
Marcos.J is offline
Old 07-10-2007, 11:33 AM
  #2379
tim fry's Avatar
Will the normal brushless speedo work ok with a spektrum setup?
I know Novak do a new spektrum one but I can get a normal one for a good price.
tim fry is offline
Old 07-10-2007, 11:48 AM
  #2380
tallyrc's Avatar
bump
honestly i'd say to email charlie or tech support at novak for the best answer to that. that said, no motors are supposed to have lots of end play..
tallyrc is offline
Old 07-10-2007, 02:22 PM
  #2381
rampal's Avatar
yes, I have full spektrum and 2 'classic' GTBs working with no problems...
rampal is offline
Old 07-10-2007, 06:47 PM
  #2382
surrealmaterial's Avatar
just a few questions guys:
1: at what temp does the ss13.5 thermal using a gtb?
2: can i thermal my motor a few times (i.e. 8-10 times) without doing any damage?
Cheers
surrealmaterial is offline
Old 07-10-2007, 10:42 PM
  #2383
Victor Vector's Avatar
How do you identify the two rotors: sintered and the other one. I have a 10.5 and it isn't as balsy as a Cameleon.
Help ??
Jacko
Victor Vector is offline
Old 07-11-2007, 01:29 AM
  #2384
jdm19turn's Avatar
the bonded rotor has the magnet exposed with either a kevlar wrap on it or off it depends if its a mod motor or not and the sintered rotor is nickle plated over the magnet and i think some of the mod motors have the extra wrap on them to not real sure hope this helps.
jdm19turn is offline
Old 07-11-2007, 06:07 AM
  #2385
Thanks on that. It makes me sintered. Still asking on 1/12th forum for roll out on 1/12th scale.
Any takers ??
Jacko
