F201
#1291
Just a question F201 guys ... i just bought a F201 kit to run on a F1 electric class here in Brazil, but now i see that the class its "2WD only" ...
So ... i woul like to know your opinion about not installing the 4WD transmission of the F201 and leting it as 2WD ... the car will perform good (at least as a F103 or something like that ?) or im toasted ??
thanks !
thanks !
#1292
thanks !
thanks !
#1293
thanks !
thanks !
#1295
So, my only solution its to get on practice time and no racing at all ??
#1296
Tamiya Type T or Type r Motor?
which is more suitable for the F201? (for short technical tracks)
thanks!
thanks!
#1297
Re: Tamiya Type T or Type r Motor?
thanks!
thanks!
Regards
#1298
For those of you running on Ozite tracks with Foam tires (is there anybody??) what width front and rear rims are you running and what compounds seem to work best. Are you cutting them down to a specific width? My local track is carpet and NO rubber tires allowed.
Thanks in advance,
Ray
Thanks in advance,
Ray
#1299
I haven't run foams myself, but I have heard of people having good success with purple all around or plaid front/purple rear. Not sure what width tires they're using, but I'd guess 26 or 28mm
#1300
Front 26 mm Shore 45
Rear 30mm 45
And use sauce......
#1301
Thanks for the info guys. I am trying to gain some excitment for this class at our track (The Gate-where the Nats just raced at).
I could just pull the rtigger and be the first and only guy at track with one and see if excitment builds after running it in practice-but-I am not excatly rollin in cash-so it may take some time.
But the foam tire info is very important to telling people what they need to run the class.
Thanks,
Ray
Thanks,
Ray
#1302
Honestly, I think you'll generate more excitement if you run rubber tires on the rug. This assumes your track allows them. The rubber tires squeal on carpet just like on asphalt. Whenever we race F201, the spectators always comment about the tire squeal, so I'd imagine that will have the same effect on your track. Pit Shimizu mediums all around is the tire you want for carpet. Sauce is good as well.
#1303
Re: Re: Tamiya Type T or Type r Motor?
Originally posted by Hardriven RC
For shorter stracks, the RR without a doubt.
Regards
Regards
#1304
Re: Re: Re: Tamiya Type T or Type r Motor?
we only have TYPE T or TYPE R.... Which one is better?
Compared both, type T would give you mor torque. Type R has more RPM.
#1305
Regards
