F201
#1682
Re: Battery Stick Packs for Racing
Originally posted by revzalot
Just wondering what good battery packs you guys running?
Mark
#1683
Trinity sells a stick pack kit that you can use to make your own pack from your favorite batteries. The kit should be around $8.
#1685
At www.promatchracing.com is it too good to be true?6 loose GP3300 cells for only $25? Then add on a Trinity stick pack kit and a Dean's plug and you get a decent GP3300 pack for $35!
#1686
Its true, but keep in mind the more expensive packs are faster. Neil, George and myself were are running their higher level packs in the 1.17+ range.
Mark
Mark
#1687
Mark
Mark
#1688
Originally posted by rtypec
...and then some
...and then some
Mark
#1689
...and then some
...and then some
#1690
a type, williams, f2001
not sure if this was discussed already....
is there a difference in terms of handling with each of the bodies?
if so, which body is better under which conditions? more steering?, less steering?
#1691
There is a huge difference b/w the Type A/Ferrari and the Williams bodies. Just the body/wing kits require different setups of the car. Generally, the Williams body/wing set is more aggressive, the Type A/Ferrari is more stable.
#1692
I was thinking someone could help me with this before I place an order regarding the FPM carbon cross brace system and the FPM aluminum rocker arm brace set:
1) does the carbon cross brace system include carbon rocker arm braces?
2) if not should I still get both? Which one will help protect the gearbox more?
Thanks!
Thanks!
#1693
#1695
I'm having a hard time finding the Ferrari livery. Looks like AMS is no longer making them.
