HOBBYWING 3656SD KV4700 Motor >
Old 04-23-2013, 02:50 AM
Default HOBBYWING 3656SD KV4700 Motor
hi there,
I am now looking for a combo, it is a HOBBYWING XERUN 3656SD KV4700 Sensored Motor & SCT PRO 120A ESC Combo
http://www.hobbyhot.com/HOBBYWING-XE...mbo-ME206.html
but, I have some questions before I make the purchase...
1. It looks like the wires are already soldered to the esc,
2. is there a battery connector already soldered to the esc,
if so waht type?
3. Do i need to solder the motor wires to the motor,
4. or can i use a bullet connector on the motor?
thanks a lot!!!
topplayer123 is offline
Old 04-23-2013, 04:24 AM
lewis110's Avatar
#1 the wires are soldered on the esc... Atleast it has been with any combo I've gotten in the past.
#2 there is no battery connector, I personally use 4mm bullet connectors..
#3-#4 personal preference I solder directly to motor, others use bullets. If you do use bullets use a good quality sold split end connector not the cheap swivel birdcage type.
lewis110 is offline
Old 04-23-2013, 10:00 AM
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
Just keep in mind that is a 4 pole motor and it was designed for 4x4 short course trucks.
Dan is offline
Old 07-12-2013, 07:14 AM
Thumbs up
I run this motor with 120@ esc and 11.1v lipo and believe me they scream my 1/10sct fry all 4 tyres on the tar and wheeling easy as
traxxas 1/16 is offline
