Like Tree34Likes
Schumacher Mi5
Old 06-08-2013, 05:40 AM
  #586
Crashmaster's Avatar
Hey guys,
Not sure if people have been testing durability yet but what spares are you typically carrying?
Cheers
Dan
Crashmaster is offline
Old 06-08-2013, 05:49 AM
  #587
Originally Posted by Crashmaster
Hey guys,
Cheers
Dan
Alloy m3x10mm screws
Knuckle
Caster block
That's it so far
cgroves is offline
Old 06-08-2013, 05:53 AM
  #588
mutley001's Avatar
Hey guys,
Cheers
Dan
After 3 meetings have just stripped 2 steering knuckles both done by hitting an immovable object pretty fast! I'd say the car was pretty durable.
mutley001 is offline
Old 06-08-2013, 07:42 AM
  #589
AdrianM's Avatar
Originally Posted by scoyle
Looking good, noticed you sneaked in a set of DCJs... all looks good.
On a side note... what do you think of the Revention Pro speedo?
Thanks! I have not run the Rev Pro yet. I usually run Hobbywings speedos but I got a good deal on it. It's seems to have all the same settings. I figure if its good enough for Rheinard and Wilk it will be fine for me...lol!
AdrianM is offline
Old 06-08-2013, 08:04 AM
  #590
Originally Posted by AdrianM
Chassis and electrics are done. I will get a body on it tomorrow.
Of all things I found a P-Dub Racing Mi3 Hard front bumper at my LHS! It fits the Mi5 perfectly.
those bumpers were the best! I wish I could still find one.
gdcopbdcop is offline
Old 06-08-2013, 10:26 AM
  #591
Trader Rating: 38 (100%+)
I've been running a pair of Reventon Pro's (one in a buggy and one in a TC) and have been happy with them. The first one I received was DOA but the other two have been flawless. I haven't had any software issues but several others have. In addition to the Pro's, I have 3 R's and they have shown no issues. They have been run in TC's and buggies. The most notable thing about them is the smoothness and mine have very strong brakes.
linkless is offline
Old 06-08-2013, 12:08 PM
  #592
haywood's Avatar
Trader Rating: 49 (100%+)
Default Step 1
The factory glued in those plastics inserts in one of my arms upside down! I don't think I will be able to get them out!
haywood is offline
Old 06-08-2013, 12:16 PM
  #593
Let me know how you get on and thanks for your comments linkless.... I'm currently running the LRP Flow Works but have just signed with Schumacher UK to run the Mi5 and am thinking about moving to the Revention Pro. So keep the updates moving Adrian when you get a chance to run it.
scoyle is offline
Old 06-08-2013, 03:24 PM
  #594
haywood's Avatar
Emailed Schumacher about this matter. Let's see how quick they get this fixed. Can't race without a RF arm.
haywood is offline
Old 06-08-2013, 06:40 PM
  #595
haywood's Avatar
Default Step 17
haywood is offline
Old 06-08-2013, 09:03 PM
  #596
TryHard's Avatar
Take a tub of acetone, place the arm above it (so the glue can only be affected by the fumes.. Not in the acetone) and leave it overnight. You should then be able to pop the inserts out, and re glue them. As long as you don't soak the inserts in acetone, they'll be fine to use again
TryHard is offline
Old 06-09-2013, 09:45 AM
  #597
Cpt.America's Avatar
Trader Rating: 52 (100%+)
So, had a great outing this weekend with the new Mi5. Yesterday was stop #1 on the Northwest Asphalt Challenge, a traveling regional points series up here in WA. All the fast guys were on hand from all over making their show.
We ran 3 quals with points (Best 2 of 3 quals) and a single A main. I qualified 2nd out of an A,B, and C main in 17.5 TC, but due to a rediculous incident with a back marker around minute #4, knocked me down to 3rd. I ran him back down but couldn't make the pass before the finish. Still a great overall with some steep competition. The car performed flawlessly.
The big change I made in the car, was the decision to run a diff in the front. Me and the other 3 Mi5 drivers there all made the change, and we ran 600,000cst oil in it. It really smoothed out the steering transitions when changing from off to on-throttle, and it really helped soak up some of the inconsistencies of the track surface... but at the cost of weight.
One big thing we all learned, (and maybe you guys already know this, but I didnt), but the steering rack slowly beds in as you drive the car. Even though the middle bearing doesn't back away, the steering rack slowly but surely gets looser and looser. Two of us had our steering racks pop out all on their own...luckily in practice, not in a race. I imagine I will have to re-tighten the rack probably once more.
Two of us stripped out our turnblocks in the front. The large bolt from underneath stripped right out. There was some fender to pipe contact.. but nothing I would consider very hard.
The only issue I currently see with my car, is I am developing quite a bit of play/slop in the front end, somewhere at the caster block/steering block. Can't tell if its the bearings, or some of the plastic somewhere... ill have to tear in and see. What a mad fun weekend.
Cpt.America is offline
Old 06-09-2013, 10:21 AM
  #598
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
Hi Brandon
all the Mi5 drivers and including kenny as well, did very well ...Brett is a good teacher..
OVA is offline
Old 06-09-2013, 10:37 AM
  #599
haywood's Avatar
Default Steering block
This has been a disappointing build to say the least. I can already tell I will miss the Xray quality plastics as one of my steering blocks stripped out the first time I ran the screw up on the bottom.
haywood is offline
Old 06-09-2013, 10:42 AM
  #600
haywood's Avatar
Thank You!
haywood is offline
