Like Tree34Likes
Schumacher Mi5
Old 12-17-2013, 09:25 AM
  #1726
Originally Posted by Mopar
Did you replace the king pin screw w/ the suggested 4mm x 14mm buttonhead screws?
Yes, and it does not make any different.
Shock Tower is offline
Old 12-17-2013, 09:38 AM
  #1727
G-kenny's Avatar
The Best thing i have found so far to remove slop is,
0.1mm shims
Run a few coats of glue along the inside of the Micro Castor block where the bearing seats, then Push the bearing in, It should take alot of force and should reduce slop
Squeeze the ball cups to remove any excess play.
Drilling a hole and using a grub screw up against the Kingpin.
I would be very surprised if Schumacher dont come up with a fix for this on the next variation on the MI5 chassis. Seems to be something everyone is not happy with.
G-kenny is offline
Old 12-18-2013, 06:07 AM
  #1728
TryHard's Avatar
Had a look at both my cars tonight, and only one corner on one car had slightly more slop than the others... took that corner apart and had a close study of where it was coming from, and pinned it down to the lower bearing being a looser fit in the bottom of the left micro-castor block.
Rather than doing the CA trick, I just put a series of crossed-etches around the inside with a hobby knife, and straight away the fit of the bearing was much tighter, and the slop gone.
TryHard is offline
Old 12-18-2013, 06:19 AM
  #1729
G-kenny's Avatar
Interesting trick! Will try this the next time I build the car up!
G-kenny is offline
Old 12-18-2013, 08:10 AM
  #1730
Very interesting. Possible to have a picture of the fix ?
Old 12-18-2013, 08:24 AM
  #1731
G-kenny's Avatar
Some new parts from Wildthing due out shortly.
G-kenny is offline
Old 12-18-2013, 09:01 AM
  #1732
snuvet75's Avatar
Trader Rating: 16 (94%+)
Talking
Originally Posted by linkless
For a Speed Passion I'd start around a 4.5 and work from there. Even the fixed (10 degree) timing motor works well at that ratio. Anything more just deadens the bottom and doesn't seem to gain any top speed.
I'm using 48p 74t spur/39t pinion at FDR 3.41 with speed passion motor. Not sure how V3 motor is different from mine(Mine is MMM but not sure if it's V2 or 3). 4.5 seems just way too high to me because I started at 4.2 and it was getting way behind the other guys with different motor. So I slowly crept my way up to 3.41. Maybe you run at very small track with short straight away. Mine is big sweeping outdoor asphalt track. But when I ran my car in a small carpet track, it was gaining top speed w/ no problem. I have to admit the torque was lacking a bit though. Maybe I should go back to 4.5 as you advised and give it a try
snuvet75 is offline
Old 12-18-2013, 09:07 AM
  #1733
poochy's Avatar
nice work TryHard, good stuff, let us know how it holds up
poochy is offline
Old 12-18-2013, 10:48 AM
  #1734
KBRacing's Avatar
Finally, my Mi5 finished and ready for first run on Sunday.......
KBRacing is offline
Old 12-18-2013, 05:47 PM
  #1735
haywood's Avatar
Trader Rating: 49 (100%+)
Default Mi5
Looks nice! I would run a servo saver otherwise you will have a short race day!
haywood is offline
Old 12-18-2013, 07:15 PM
  #1736
+1! I use the x-ray servo saver. I think it's the best one out there.
gdcopbdcop is offline
Old 12-19-2013, 12:05 AM
  #1737
That depends on how much u crash... i have done 3 races and some practices with Core alu servohorn without any problems!!!
Gillblade is offline
Old 12-19-2013, 02:34 AM
  #1738
TryHard's Avatar
Here is the link where I got the technique from...
http://www.petitrc.com/reglages/asso...TC6_BuildTips/
TryHard is offline
Old 12-19-2013, 09:26 AM
  #1739
haywood's Avatar
I suck!
haywood is offline
Old 12-19-2013, 09:30 AM
  #1740
Thanks ! I will try it out.
