Like Tree34Likes
Schumacher Mi5
Old 10-30-2013, 03:38 AM
  #1576
R/C Tech Elite Member
DiscountRCStore's Avatar
Originally Posted by haywood
I really disliked the stock top shock mount setup as it would bind up with my bleeder caps. The Wild Thing mounts really allow for free movement of the shocks. I added 3mm countersunk washers along with the provided screws that Phil at DiscountRc recommended.
..very glad it worked out for you.. it really finishes it off nicely ..
Originally Posted by Shock Tower
Could anyone post pics of there servo and servosaver. Still are on the look out for the right combo (servo postions and saver).
My setup seems to get in the way af the tie rods going from the servosaver and from the steering rack to the left wheel. mayby I am doing a rookie mistake, so I would like to see others setup.
.. maybe this will help.. using a GM94050 servo with Xray X-stiff servo saver ( re-engineered abit, lol )
..p
DiscountRCStore is offline
Old 10-30-2013, 04:25 AM
  #1577
TryHard's Avatar
Something to mention as well, Schuey do a Servo Saver specific mounting plate for the servo mount;
http://www.racing-cars.com/pp/New_Ca...Mi5/U4341.html
Can help with clearance, and the mounting holes are moved back a little I believe. (I don't personally use it, as I run a solid horn only )
HiH
Ed
TryHard is offline
Old 10-30-2013, 07:25 AM
  #1578
.. seems Atsushi Hara may be a fan of the Mi5; here's a pic of it at the Jet Cup from his Facebook page
..p
Old 10-30-2013, 09:29 AM
  #1579
Trader Rating: 17 (100%+)
Will be running either a 5.5 or 5.0 motor with 64p 90 tooth spur. What pinion and FDR should I be seeking?
Thanks!
meddman is offline
Old 10-30-2013, 10:01 AM
  #1580
Anyone running hard bumbers on their Mi5? Which ones fit? Do you find the bumper mount is still able to absorb the hits with a harder bumper or does it start to crack?
cgroves is offline
Old 10-30-2013, 10:39 AM
  #1581
I cut a x-ray hard bumper to fit. works way better than the soft schuey bumper. back in the day when pdub was running Schumacher usa, he came out with a bumper especially for the Schumacher touring cars. it is about the same hardness as the x-ray one. I haven't had a problem with the plastic parts breaking. but id rather break a plastic bumper than break the arms or other front end parts.
gdcopbdcop is offline
Old 10-30-2013, 10:54 AM
  #1582
..p
Hes trying every car under the sun lol dunno if the schumacher will be to his tastes, will be interesting if he says anything about it.
either way i want him to go to yokomo but im biased and a yokomo fan boy lol
PurcyP is offline
Old 10-30-2013, 10:56 AM
  #1583
jdm19turn's Avatar
I'm actually using the pdub hard bumper which was made out of the parma hard foam there hard to find but parma still sales the hard foam you just have to cut it your self tho just trace out your stock bumper
jdm19turn is offline
Old 10-30-2013, 11:04 AM
  #1584
Thanks!
.. To begin, 90T is far too small to run Mod with; consider a 114-116T spur.. There are some other variables to consider ( length of straight, esc profile, the exact wind ) in Vegas we were 8.5 - 8.9 with Fantom 5.5T motors.. I'm sure some others can chime in and add to this.. Consider reading through here:
http://www.rctech.net/forum/electric...-modified.html
The first several pages are absolute gold for tips on running Mod .. Hope it helps ..
..p
Old 10-30-2013, 11:14 AM
  #1585
So I should be shooting for that FDR for mod?
meddman is offline
Old 10-30-2013, 11:23 AM
  #1586
cementsurfer86's Avatar
HiH
Ed
Did you countersink those holes on the hub carriers? Or are those option extensions?
cementsurfer86 is offline
  #1587
So a 114 spur with a 24 pinion gives a FDR of 8.55 , sound better?
meddman is offline
Old 10-30-2013, 11:55 AM
  #1588
.. I noticed that as well.. Very nice ..
That should be an okay place to start.. also consider leaving your end bell timing alone.. zero timing to start... there's a post in that thread and it talk's about when and how to watch your gearing based on the temp of the motor and esc; whether ones running hotter than the other.. I'd encourage you to spend some time in there.. It's a pretty quick and fascinating read..
..p
Old 10-30-2013, 02:46 PM
  #1589
poochy's Avatar
Originally Posted by G-kenny
Remove the 4deg micro castor blocks and bearing. Using a cotton bud coat the inside of the blocks where the bearings seat with super glue, 2 light coats is enough and using a pair of pliers squeeze the bearings back in, and hey presto.....No Slop
my mi5 is brand new so no slop yet, but ths is exactly what i was going to try...either ca, threadlock, or a of a slit of paper.
poochy is offline
Old 10-30-2013, 04:11 PM
  #1590
TryHard's Avatar
The answer is both
I actually counter sunk the whole car, bar the top deck (have a look at the camber plates and arms), and took the opportunity to make up some different steering plates with the holes moved inwards a little.
There are a couple of other mods on the car too..
TryHard is offline
