Team Durango DETC410 >
Like Tree4Likes
Old 03-13-2014, 12:11 AM
  #361
Originally Posted by Phoenix82
Hi Jordan. can you explain what your doing with the bearing carriers? or even take a pic?
Nick K
Friday is too far away... cant wait.
Hi Pheonix,
It's not something you MUST do, it just holds the bearing a little tighter. Basically looking in to the the hub (where the bearing seats) score the shiny surface with a hobby knife so it has a slight raised area for the outer race to bite in to. If this still doesn't make sense I will take a video later on to show you.
JC
JordanC is offline
Old 03-13-2014, 03:42 PM
  #362
ewashburnaf's Avatar
Trader Rating: 14 (100%+)
What's a good starting point for diff oils on a medium bite carpet track? 17.5 blinky.
ewashburnaf is offline
Old 03-13-2014, 03:49 PM
  #363
whats the car like, as harper drove the bd7 alot it feels like the car is an xray looking car that drives like a bd7?
Bappe is offline
Old 03-13-2014, 03:59 PM
  #364
Tdiddy's Avatar
I'm curious about what is meant by "scoring the bearing carriers with a knife to make things a little tighter" as well.
And for the inserts, I've never had any slop develop from the inserts in the hubs or front carriers...don't know why you would want to glue them in place. Hinge pin to insert slop yes, but not insert to hub slop.
Tdiddy is offline
Old 03-13-2014, 06:26 PM
  #365
Start with 2K, at our place RJ is running 3K.
ercwhtsd is offline
Old 03-13-2014, 06:28 PM
  #366
"scoring" is nothing more than raising the contact surface of the hub in small controlled places.
It is a quick fix for when a housing becomes loose or plastic stretches
ercwhtsd is offline
Old 03-13-2014, 06:33 PM
  #367
SH
Trader Rating: 20 (100%+)
So with the hub facing you without bearing installed, get your hobby knife & lightly make a small groove (lightly cut) from the inside out being cautious not to cut your self. You don't need a lot of pressure just enough to "score" it.
SH is offline
Old 03-14-2014, 10:43 AM
  #368
3rd photo.
http://www.petitrc.com/reglages/asso...TC6_BuildTips/
cyclonetog is offline
Old 03-14-2014, 03:09 PM
  #369
all right put up your hand if you purchase this chassis. if so plz post some build pics
thanks
TeamThibault is offline
Old 03-14-2014, 04:11 PM
  #370
already ordered! As soon it`s available in germany I`ll post a detailed building report if you want....
loomumbaa is offline
Old 03-15-2014, 04:09 AM
  #371
Sorry I haven't run on Carpet yet. Running indoor high Grip Asphalt I alternate between 5K and 7K for mod. When running outside on lower grip 3K to 5K.
JordanC is offline
  #372
Originally Posted by cyclonetog
Spot on!
JordanC is offline
Old 03-15-2014, 04:53 AM
  #373
Thanks. I'll start at 3k and work from there.
Old 03-15-2014, 02:14 PM
  #374
Potoczak's Avatar
Trader Rating: 120 (100%+)
Are the shocks on this car considered shorty shocks or standard???
Potoczak is offline
Old 03-15-2014, 08:07 PM
  #375
Tdiddy's Avatar
You don't need to do that with new hubs...
It even states this in the text above the picture but if its part of your build process...it couldn't hurt anything.
I have "extra steps" to building kits too, all leftover from when I raced other brands over the past 20 years.
Lets see some build pics guys!
Tdiddy is offline
