Alex Racing Stinger
#153
You just need to use the titanium shock mounts, then it's only one nut you need to remove, with the standard long screw and bolts it was a bit of a pain.
It's about time they got rid of those plastic shock caps though, just get them to put the yoke items in the kit
#154
is it just me or does the r2 seem to be the best of the alex cars, i bought one of rcmonk, and i love it, it rivals my 414m2 as the best car iv owned, i think it was a xenon stage 2 he sold me, but man what a car, easily the beast shaft iv owned, all other versions by alex, just seem pedestrian!
#155
An R2 with Xenon or Speedwaypal conversion is arguably better than an R3. I do own both and actually race with an R3 in the local national modified championship, when I find the time. My younger brother uses the R2 with Xenon conversion and has won the most races in the national stock class this year with it
If there is something I would change from the R3, would be the steering rack. With the standard rack it is impossible to get full steering using the outside holes of the front knuckles. With the pal rack it is much better but still not enough sometimes
However since the Stinger has a different suspension geometery maybe the steering rack will be good enough ey. We have to wait and see
#156
By the way, Dave ...
Maybe through your contacts you can convince Alex Racing to build a locked diff for the Stinger too
Using the normal diff but bit tight in front, the outdrives are too fragile! Never had problems with same diff at the rear section though. Speedtech's spool is good but not durable especially in modified racing. We only managed to make a good one in Malta using the original one way cups which are press fitted to an aluminium shaft. However they come very expensive and sometimes we have to wait a lot to get them
Would be much better if Alex Racing make a locked diff too. I am sure many guys will go for it. From my side will try to push for it too, but sometimes you seem to have more luck
#157
Not to be negative....
but it won't sell. You read it here first. Alex should scrap it as I'm sure it will go over like a lead balloon. What is he thinking?
#158
Re: Not to be negative....
With a few tweaks there's no reason it won't sell just as well as the Barracuda and possibly even better since there is a larger market aware of Alex Racing than ever before.
There just needs to be some good feedback from testing and interest will grow.
#159
Tech Legend
Trader Rating: 51 (100%+)
#160
Re: Re: just a little suggestion...
Originally posted by JDM_DOHC_SiR
?? EXAMPLE?? how?.. I find changing the damper angle quite easy on the Cuda..
-Dave
-Dave
I cant see it being too hard to incorporate that design from the start and was wondering why they dont do it?
#161
A thought just came to me today, what's the problem in the extra width, the motor and battery (the heaviest items on the car) are placed really close to the middle anyway... the extra width also serve as protection to the valuable electronics... Can be an added bonus...
Please no more rack steering, go back to the R2 steering, so much more precise... and a revise shock cap and shock tower would be good, the most outer hole on the front and rear are almost impossible to use regularly...
#162
one of the problems with a wide chassis is that it will scrape the deck on sweeping and most hard cornering situations of you run low ride height. Also i cud never use the outer holes on my rear tower on my r2 because the shock would foul on the body posts, a bit of a design flaw...or have i been missing something all these years?
#163
I have seen a setup from the Alex Racing website (Japan) that someone was using the rear shock tower for the front with the rear shock position at the most outer holes (where the body mount locate), now here is my question. Is there any advantage of a wider shock tower for the front, and will they be considering an option for the Stinger. And is there any advantage of mounting the body poles on the shock tower, from what I gather, the Yokomo SDW comes with a seperate piece that you can mount the body differently. So will that be considered?
#164
seems to have gone quiet in here is there anymore news?
#165
looks ok
I reckon the stinger looks ok, you've got to love the detail on the diffs; but why didn't they release that concept with the gorgeous molded cf tub and braces
