spintec I.C.C charger
#316
Originally Posted by XingXing
this charger, charges only 1 battery, it is no use for nitro users, tx packs, lipos, pb cells, rx packs, stick packs, and only discharges at 10amps. i still need another charger and seperate discharger.
i wouldnt pay more than $200 for it.
#317
Not sure where you got your info but it can charge stick packs, tx and rx packs on its external connection. And li-po will be included in a future firmware update. Not sure what pb cells are but i'm sure a later firmware version will make it possible?
also reason why i wouldnt pay over $200 for it.
I got a ctx-c and it doesnt overcharge batteries to get top performance. and i have match packs anyway. so long as you buy rfom a good matcher, they should stay matched thoughout its life, if tray them afterwards.
#318
Originally Posted by TRF415boy
This charger is not designed for nitro users anyway. $200 you must be kidding, this is the price of the Much More cell master, it's like you say you want to pay the price of a volvo estate for a Rolls Royce...
#319
I was thinking about something after reading thru the manual .....If each cell is charged individual and you are charging at 5 amps then shouldn't the power supply needed be a 30 amp supply??? I see in the owners manual that a 10 amp power supply is recomended. I'm thinking its individual cut-off per cell. The name is bit confusing...
#320
Originally Posted by Sluggo
I was thinking about something after reading thru the manual .....If each cell is charged individual and you are charging at 5 volts then shouldn't the power supply needed be a 30 amp supply??? I see in the owners manual that a 10 amp power supply is recomended. I'm thinking its individual cut-off per cell. The name is bit confusing...
A 10 Amp PSU provides 10 Amp x 12 V = 120 W, which is well enough, you could even charge 3 packs at 5 Amp with a 10A PSU.
#321
thanks for clearing that up
#322
The result is that as the pack gets older, the difference in charging time between the cells gets bigger. We try to keep it as low as we can by equalizing the cells but the next step is what the I.C.C. is doing : charge each cell individually.
#323
well when i discharge and equilize them the lights flick off at same time or within a few seconds of each other, that to me means they are still matched.
in anycase, if you cells are not matched, an ICC wont do anything for you coz its discharge charateristics is whats important when racing. icc may prevent a cell from being over charged but thats about all, it still always best just to buy good quality matched packs.
#325
Originally Posted by V12
Just read at a German forum price will be 380 Euro what is about 460$ and should be available next month.
Holy Crap...!!! Thats quite....Ermm.....EXPENSIVE...!!
#326
Hahahaha, I would be so strange if the I.I.C is more exspensive in holland then in amerika because spintec is a dutch corparation , if it's 200 dollar in the US and 460 dollar in holland that would be crazy talk because : 460$ = 380 euro & 200$ = 165 euro That's 215 euro's diffrents , in theory : you could
buy 2 I.I.C's in US for the price of 1 here in holland or germany .
Greetings Florian (Also from Holland )
#327
Cause, EUR380 is really outta my budget!!
#328
But matchers charge cells INDIVIDUALLY then measure the discharge, any difference in charging up time is not noted.
So you put the 4 or 6 cells together and charge them in series, as you do not know the individual charge times you will have maybe 1 very slightly overcharged cell, 2 at virtually 100% and 2 or 3 not quite there.
Enter the ICC, it makes sure EACH CELL HAS A FULL CHARGE so you have 100% in each cell from the start, THIS WILL MAKE YOUR CAR FASTER.
You already know your cells have the same discharge characteristic so no reverse polarity at the end of the run (this would be an extreme case)
#329
i'm sure many people will want this, coz they think it will work, but end of the day price will determine whether this will sell or not, its generally regarded the GFX and the CDR5000 are the best chargers going around but only peole with heaps to spend buy it.
#330
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
Price for I.C.C charger
been talking to my mate Erik via E-mail (trying the chaff some more stickers )
this is Euro price & GB pound price
How are you! Good to hear the unit is still going fine. Recommended retail price for the ICC will be around EUR 349,- (that's about 239 GBP).
so usa are looking around $390.00
