Tamiya TT02 Thread
#796
Hey guys,
does anyone of you know if I can fit a 74t 48dp spur gear with a 32t 48dp pinion with the original motor mount in the TT-02?
I'm trying to get as close to a 6.0:1 and can't find a 65 spur in module 0.6.
I compared my TT-02 on short wheelbase and the Carrera RSR body with my TA-02SW.
Same gearing, same tires, ball bearings, same weight, same ESC, same Motor - TT-02 with optimized setup, TA-02SW except changes mentioned completely box stock. Ran with both chassis almost the same lap times.
I can't say that the TT-02 is much better on short wheelbase than the TA-02SW - might be different on running long wheelbases.
#797
Hi. Bought a tt-02 to race in a tt class. Not using the kit slick tires for racing, just for shaking the car out in the parking lot. The tires in the kit didn't come with inserts. Will they work without them or should I make inserts out of some sct open cell foams that I have? Tks in advance.
Richard
Richard
#798
Hello
I'm playing the standard tt02 with teampower blackcan brushed motor. I bought the yr front upper arm to make the car have front camber adjustment. Overall the car runs well but the problem is, when using metal upper arm, the turnbuckles will deform easily. Is there any alternative method to achieve adjustable front camber other than buying a type-s chassis?
#799
Some really cool looking TT02's there. I am in the middle of making a TT02-S race spec. I also recently got the TT02D Type-S which has more goodies than the std TYPE-S but is the same price!
http://www.thercracer.com/2015/09/ta...build-and.html
The specs are:
-54501 Alu propeller
-54502 Alu propeller joint
-54500 High speed gear set.
-54571 Alu motor heat sink.
-54639 Carbon front damper stay.
-54640 Carbon rear damper stay.
-54550 Low Friction step screws.
-54649 Diff Lock Block.
-53682 Alu Bumper stopper
-42273 TRF dampers
and a ball beaing set
#800
For those of you wondering as I did: Ordered a 74t 48dp Arrowmax spur and a 32t 48dp Robitronic pinion. Fits just fine when using mounting position 'J'.
#801
Thanx for the update!! Is it possible to use a larger pinion perhaps a 34 48dp with the motor mount? In our club competition FDR is set at 5.0. I want a FDR at approx 5.5/5.6.
#802
Looking at the space left between chassis and 32t pinion I'd say it fits, but I wouldn't say that I'm sure with a gun pointing at my head
Larger problem would be the mounting position to get the needed space.
Maybe a 30t pinion module 0.6 in mounting position 'J' in combination with a 64t spur is the better way to try - that would end up in a 5.55 FDR. Only thing is I'm not sure if there's a 30t m0.6 pinion is available in steel...
#803
I'm sorry, but since I don't own a 34t pinion I'm not able to check.
Let you know of it will fit and what the mounting position is.
#807
have any of you guys been running diff oils in the TT02 diffs? I know I read some place that anything less than (i think) 300k will just leak out - if anyone is running less than that, how are you sealing the diffs?
I plan on running the TT02 spec class for TCS, so anything has to fit within TCS rules and tech... I'm not overly worried about the thicker stuff, as I'd probably run 300k or 500k in the front diff, so I get a spool-like action, but still fit within the TCS rules that the diff has to work
any ideas?
any ideas?
#808
any ideas?
any ideas?
#810
You can adjust the amount of gum used. Make the gum into 3mm balls and add into the diff one by one until you think it is tight enough. I will put some kyosho diff grease together to make the diff smoother. The pros of using gum instead of silicon oil in a unsealed gear diff is that the diff will not loose easily.
