Tamiya TT02 Thread >
Tamiya TT02 Thread
Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree1387Likes
Tamiya TT02 Thread
Last edit by:
Print Wikipost
Old 05-21-2015 | 04:14 AM
  #721
this part seems to be restricting any camber style movement aswell as the lower arm?[IMG]<a href="http://s723.photobucket.com/user/connormorrison1996/media/IMG_1145_zpsvcrbg0tl.jpg.html" target="_blank"><img src="http://i723.photobucket.com/albums/ww236/connormorrison1996/IMG_1145_zpsvcrbg0tl.jpg" border="0" alt=" photo IMG_1145_zpsvcrbg0tl.jpg"/></a>[/IMG]
connormorrison9 is offline
Old 05-21-2015 | 04:15 AM
  #722
[IMG][/IMG]
  #723
[IMG][/IMG]
Old 05-21-2015 | 05:09 AM
  #724
SagadSetup's Avatar
Originally Posted by connormorrison9
[IMG][/IMG]
My best guess would be is that you need to upgrade your axles to CVDs.
Here's one of the links: http://www.asiatees.com/display?bran...&c=product-int
SagadSetup is offline
Old 05-21-2015 | 06:34 AM
  #725
Yep front universals are pretty important on the TT02 as the dogbones can pop out (Fusion hobbies in the UK sell a set for cheap).
How much camber are you trying to add? Are you looking at crazy Drift levels or race levels as we only go to about 3 degrees max for racing.
Qatmix is offline
Old 05-21-2015 | 07:12 AM
  #726
SagadSetup's Avatar
+1
In my honest opinion. The TT02 Type S is the best kit I would buy. It has the adjustability, shock towers, and bearings included. Has the potential to become a very competitive chassis. Lots of third party support on hop-up parts if you want to drift: http://www.broadtech.hk/eagleshop/sh...TT02-14-AL-LBL
As a bonus, it can perfectly fit those lovely Tamiya bodies sought by Tamiya fans like me.
Need setup tips on the TT02? Go to: http://www.thercracer.com/2014/08/ta...-and-tips.html
Old 05-23-2015 | 04:20 AM
  #727
im looking into crazy drift camber aha espcially as the wheels offset is rubbing on the body, basically i need enough for it to steer without hitting the body and so it looks clean?
Old 05-23-2015 | 07:16 AM
  #728
Ok, I thought that might be the case, I will have a look to see how far I can take the camber.
Qatmix is offline
Old 05-23-2015 | 07:31 AM
  #729
here is what im working with,
[IMG][/IMG]
Old 05-23-2015 | 10:57 AM
  #730
Now that the type-D has some body shells associated with it, I would just get that (unless there is another TT-02 body that is desired in a base kit) or definitely get the Type-S for racing.
Hayling is offline
Old 05-23-2015 | 07:19 PM
  #731
I have a tt02 set up for drifting. Not much info on drifting on RCTech but what is the advantage of 'crazy drift camber.' Does it reduce grip so it drifts more?
ic-racer is offline
Old 05-24-2015 | 03:49 PM
  #732
BoneCrusher's Avatar
Default TT02 Gear Adapter fit TT01?
I've asked a few of the regulars thru PM but thought I'd just put it up on the main thread too.
Planning to run my old TT01 in a blinky 21.5 class. Need to get FDR down to about 3.6. I know the stock setup is limited to 5.72 (55t spur gear and 25 pinion). But I got an adjustable motor mount made so I'm not limited anymore. But would like to run 64 pitch spur gears. Something like a 64 pitch 73 teeth spur gear and a 64 pitch 53 teeth pinion (currently not sure if this would even work).
My question is:? Which is a better fit for the TT01 in terms of a spur gear adapter:
3Racing TB03 spur gear adapter
http://www.rcmart.com/3racing-tb0314...3-p-27689.html
OR
Tamiya TB03 aluminum spur gear mount
http://www.rcmart.com/tamiya-54094-t...t-p-28272.html
OR
Tamiya TT02 High Speed Spur Gear Set?
https://www.tamiyausa.com/product/it...oduct-id=54500
Anyone have a good gearing combo (and what brand spur gear) that also might avoid grinding down the cover over the pinion when the motor is mounted?
Any other advice is much appreciated. Thanks,
Ivan
BoneCrusher is offline
Old 05-31-2015 | 07:30 AM
  #733
additional to the camber question, is there any mods that can give a much bigger steering lock to the tt02d
Old 05-31-2015 | 05:01 PM
  #734
OR
OR
Ivan
I have the High Speed Spur Gear set in both my TT02s. I tried it in a TT01 and it did not quite fit. I think it will fit if you grind a way some plastic as I recall. I'm going to try and set up my TT01 for VTA and need to re-address this issue myself.
ic-racer is offline
Old 06-18-2015 | 10:18 PM
  #735
just bought myself a TT02-S. still waiting for a few hopups so i can get started on building it.
the guys are right, i had to hold back from pressing the buy buttons on a lot of upgrades for this thing. so much is available.
voodoo is offline
