Tamiya TT02 Thread >
Tamiya TT02 Thread
Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree1387Likes
Tamiya TT02 Thread
Last edit by:
Print Wikipost
Old 02-05-2015 | 06:06 AM
  #616
The Type-S version isn't supposed to be a rally version, only onroad purpose.
I would go for the R version cause it has several option parts aswell as limited to this kit only rear uprights with 3° of toe-in, options are 2.5° toe-in.
addicted2blue is offline
Old 02-05-2015 | 05:03 PM
  #617
Originally Posted by Hayling
Very valuable post - thank you. I have a sheet of bumper-grade thermoplastic that I am not very skilled at working with, so I ordered two of the Square ones from Bonzai for a nice clean look and fitment.
These types of "guards" can make just about any car durable from what I've seen at our local track from people who make their own. I like their design too, and the width is perfect.
So, this fits without any trimming?
I forgot to note that I am also running the reinforced grey uprights from the drift spec model (and also the upcoming truck I think) on one of mine which may have also contributed to a lack of breakages.
These are also available from banzai hobby via special order.
Cheers,
Crouch
Camocrouch is offline
Old 02-05-2015 | 05:21 PM
  #618
I was thinking the same thing Blue but then I noticed the suspension and wheel area design of the type s is very similar to the buggy variant and the XV-01, which should allow for greater suspension travel and free-er movement, important for rally and something that I struggle to maximise on the stock setup.
Also having metal rods attaching the suspension arms to the chassis should also reduce friction, another struggle point for the stock version.
With the other type r parts being easily available as hop ups, it will be really interesting to see the price difference between the type r and s, I think that will be a deciding factor.
Cheers,
Crouch
PS: tamiya usa website listing the type r with plastic bushings, not bearings - another consideration.
Old 02-06-2015 | 04:52 AM
  #619
Rally aside, it seems to me that the Type-S is still a better deal, especially considering that the aluminum drivetrain parts are surprisingly inexpensive from Tamiya.
If the R came with the aluminum steering components, maybe it would make sense, but I think that having the bettter suspension design still makes the S worthwhile. You don't get the 3 degree aluminum rear hubs of course, but the Type-S already has 3 degrees of toe-in, according to Tamiya.
A of right now, my plan is to get the type-S kit and add the centre shaft and joint cup set, the high speed gear set and the Yeah Racing motor mount. Should make for a fun little club racer and outdoors runner. I can always raise the suspension for more clearance if I want to put on the rally tires.
ErikO is offline
Old 02-06-2015 | 09:50 AM
  #620
Theibault's Avatar
Just finished part 3 of my TT-02 Type S build. Sorry for the delay, I'm heartbroken after having put my best friend Kota down on 1/21. I am feeling better so on with life and the build. Hope you guys enjoyed this as much as I did making it.
http://youtu.be/GpknczFVxpI
Theibault is offline
Old 02-06-2015 | 11:41 AM
  #621
Hey Theibault
Sorry for your loss
I've enjoyed your build videos. My only questions/suggestion is that I'm wondering if you've ever considered using some blue threadlock on your metal parts when ? It's something I've always done, especially on things like motor mounts to prevent them from vibrating loose. I use the blue Gel threadlock as it's much easier to work with than the drippy stuff.
As for the body, I vote GTR!
ErikO is offline
Old 02-06-2015 | 01:06 PM
  #622
Theibault's Avatar
Originally Posted by ErikO
Hey Theibault
Sorry for your loss
Thanks for the kind words. I do use blue thread lock on my offroad kits. I'm not too worried about it on this from prior experience, but if anything does come undone, yeah it'll go on.
Old 02-08-2015 | 08:52 AM
  #623
Smile's Avatar
Camocrouch, knowing that you own both the sedan TT02 and TT02b, is it possible to use the Neo Scorcher body shell as a dust cover for my rally TT02?
Smile is offline
Old 02-09-2015 | 04:02 AM
  #624
G'day Smile,
Yes, the neo scorcher buggy body works well as a dirt cover.
I've got one mounted on buggy body posts buts it's annoying to work with the posts so I'll be switching to Velcro.
You have to trim the leading edge a little if you're using knobbly tyres as they will impact the body when turning.
There's also not much room for electronics and cables under the neo scorcher buggy body so you have to keep it nice and tidy. I wish they'd hurry up and develop a TT01 type E style top brace for it to mount electronics too.
On this point the Dual Ridge body set could work better but may not fit as well under a car body - not sure though.
I'll post some pics in the rally thread soon.
Cheers,
Crouch
Old 02-09-2015 | 05:06 AM
  #625
Smile's Avatar
Nice! It sucks that the Neo Scorcher body is a 9 digit spare part though... It would take a while before I can get it if ever I decide to order one.
I actually already have an XV01, but I figured that the TT02 would be better for mud because it is a lot easier to clean and metal parts count is low.
Smile is offline
Old 02-09-2015 | 08:39 PM
  #626
I sound like a broken record but try banzai hobby.
They've supplied me with the 9 digit spare parts for the TT02B buggies and the reinforced drift parts for the sedans.
Costs a little more and takes maybe an extra 10 days but I've always been impressed by their service.
I've got an XV too and yes, to clean the TT you just turn it upside down whereas the XV has more nooks and crannies.
I think the XV overall is a better rally car but I'm still in my early days testing it. As a drifter it certainly seems better setup out of the box.
I enjoy all the tweaking and testing, getting the most out of an entry level kit (cheaply!) which Is why I like the TT's.
Cheers,
Crouch
Old 02-14-2015 | 03:46 PM
  #627
Hey guys,
I just bought a TT02 and preparing to race in the Spec/Novice class at Tamiya Raceway in Aliso Viejo. What size pinion and spur should I run? I am running the torque tuned motor (54358) and a Tekin RS ESC. The track dimensions is 170x60 feet and is asphalt.
Thanks for you help!
looklikeaflip is offline
Old 02-19-2015 | 10:45 PM
  #628
Hi All - I'm having some issues getting low enough ride heights with my TT02 fitted with the following dampers and spring set.
It appears the yellow springs on this "tree" is the same size, and number of coils, as the yellow tabbed ones that came with the TRFs (white color, with yellow tab on end.) This set comes with an extra-stiff spring? What are these?
Also, I have this set of springs, which I thought might be for a M-chassis, but they say rally, fwd, and touring car too. Pretty confused.. not sure what I bought!
Do I have what I need, or if not exactly, can I use a combination of these for parking lot club racing? I already put the blue ones on the front of my TT-02 which can be seen in the middle of the row in this pic. It has the stock white (yellow) ones in the rear. It was advised to do a blue/yellow setup for outdoor asphalt.
Also, I think I might not be threading the bottom part that connects to the ball joint all the way. Do you thread them til they just stop, or just measure the overall length until they are all equal and adjust from there?
Thanks for any guidance!
Hayling is offline
Old 02-20-2015 | 02:01 AM
  #629
Djchow85's Avatar
All these spring sets should be fine for racing. Assuming you have them for the right shocks, I'm guessing these may probably fit your generic 50-60mm shock. What height are you aiming for? I last had my tt02 set for carpet, when it came to car park bashing it was way too low as there's rocks all around.
What I see a lot on rctech is that people can ask for the best setup but there are so many factors, surface condition/type etc.
Have a look at thercracer.com
I think the m chassis run shorter springs? 4wd, touring car springs should be the same for the TT02 with your general wheelbase. A rally car is pretty much an on road car with raised ride height so it's fine.
Not sure on your last question. In terms of what works, you'll need to experiment. The joys of fine tuning.
I reread your initial question. If you flip the rear hubs this can lower the back. The fronts can be lowered too with the different arrangement at the arms - check the manual as it mentions it there.
Djchow85 is offline
Old 02-20-2015 | 04:44 AM
  #630
I'm just trying to confirm the particular model of TRFs and the springs as being a match in the first place, and then assuming that if they are, they are suitable for putting on the TT-02.
Hayling is offline
