Tamiya TT02 Thread >
Tamiya TT02 Thread
Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree1387Likes
Tamiya TT02 Thread
Last edit by:
Print Wikipost
Old 01-17-2015 | 09:24 PM
  #586
I did some extra testing with the TT-02 and my fastest laptim improved with 0.1s with a fastest laptime of 11.940s.
Used softer damper oil and other tires.
Think i can go even faster cause this was done with batteries i'm using for practice, my other batteries give me more power.
This has been proven with my TRF418, i gained about 0.3seconds in my fastest lap.
addicted2blue is offline
Old 01-17-2015 | 11:13 PM
  #587
GT Goose's Avatar
Default Suspension Setup?
I'm running a TT02 with a pile of Hop-Ups. Aluminum suspension, oil shocks, aluminum steering linkage, driveshaft, universal axles, uprights, etc.
3.9 FDR (60t spur, 40t pinion).
21.5 turn Speed Passion VTA class.
2.5 degree rear toe-in.
1.0 (or a little less) degree front toe-out.
0.5 degree front negative camber.
100,000 weight front diff oil, 2000 rear.
Cornering issues.
Good turn initiation, followed by savage under-steer.
Suggestions?
General advice on setup welcome.
GT Goose is offline
Old 01-19-2015 | 08:24 AM
  #588
Theibault's Avatar
Episode 2 of my TT-02 Type S build is live. Again, if you enjoyed this, please help me out by liking, commenting, and subscribing!
http://youtu.be/f6I6BMA5q4I
Theibault is offline
Old 01-19-2015 | 09:01 AM
  #589
Cornering issues.
Suggestions?
Check your ride height, it seems to me that once you turn in the chassis is rubbing on the ground, that can cause the car to under-steer dramatically.
Is is under-steering on power or off power?
Qatmix is offline
Old 01-19-2015 | 12:24 PM
  #590
Djchow85's Avatar
your camera angle and lighting is good. Only thing I think is getting right into the build/video etc. What I personally find ruins a clip is when someone is talking for a good 1-2 minutes and not getting into the video. Keep up the good work
Djchow85 is offline
Old 01-19-2015 | 03:43 PM
  #591
Theibault's Avatar
Thanks for the kind words and feedback. I appreciate it.
Old 01-25-2015 | 04:23 AM
  #592
Smile's Avatar
What you should do is say what you say before the build during the build. If you find this difficult you can edit the video.
Smile is offline
Old 01-28-2015 | 02:03 AM
  #593
A new TT-02R (84409) is announced at the toyfair of Nuremberg.
Looking forward to what new parts that this car will have.
Below is a link to Qatmix's website where you can see the car and other new releases from tamiya.
http://www.thercracer.com/2015/01/ta...-releases.html
Old 01-28-2015 | 03:49 AM
  #594
longuylander's Avatar
Interesting about a TT02R, but that begs the questions... what are the differences between this and the Type S? Why would Tamiya release two these two cars so close to one another?
longuylander is offline
Old 01-28-2015 | 05:06 AM
  #595
Good question long guy.
The type s definetly has more significant changes with the addition of the different suspension arms, carbon damper stays, etc, plus most of the type r specs.
To me it seems like an in between step between the stock and the type s but it does rather complicate the lineup - will be interesting to see the price difference.
I think I also see alloy uprights in the rear...
I like the look of everything else - bodies for the drift kits, the DT03 truck, even the TT02 truck will be a cool option yet still keeping everything on the TT basic platform. I hope the TT truck has some sort of long suspension travel setup that I can adopt for rally!
I also hope they do one of those truck kits like the DT03T for the TT with the wide wheel setup...
Cheers
Crouch
Camocrouch is offline
Old 01-28-2015 | 05:27 AM
  #596
Just had a look at additional pics at Tamiyablog, looks like the TT truck doesn't have much in the way of extra shock travel (although I can't see the lower arms), adjustable turnbuckles for front toe, the smaller / metal dogbone /gearbox out drive setup and the reinforced grey pieces like the drift spec models.
These pics also confirm 3degree alloy rear uprights for the type r, high speed gear set, medium narrow tyres and again the smaller / metal dogbone /gearbox out drive setup...
Still confused as to where the type s and r sit in the lineup.
Cheers,
Crouch
Old 01-28-2015 | 05:53 AM
  #597
Cheers,
Crouch
The TT-02 type-R is a bit of a disappointment. It is also a limited edition kit (all 84 kits are limited) the Type-S is a proper kit (58600) so will stay around.
I want to see pictures of the TT02 carbon towers, I've seen the TT02S ones but I have been told there are some for the std TT02.
Qatmix is offline
Old 01-29-2015 | 05:25 PM
  #598
Darn, I thought it would be a permanent kit. Oh well. We are trying to set up a TT-02 class here in TX, and keeping an eye out for options.
Reason I'm posting mainly, is because I followed your guide online while getting into touring cars (thanks btw - I wouldn't have gotten into RC without it to be honest) and have a few questions about my TT-02 builds. Have 3 different ones (2 regulars and one D), and all the hop ups.
1) It will be run in soda treated parking lots. How should I set up the damper oil, springs and rebound? I have the tamiya spring set, and some HPI silvers that are popular. I also have the short TRFs, kit oil shocks, and even some aluminum M-chassis dampers I could put on there (and spring set), which lead to the next question.
2) It's been mentioned to build the kit at rally height so that the spacers to not contribute to breaking pieces on the front end. Would one then need to use m-chassis dampers to get back down to normal TC ride height?
3) Should I lock the front like a spool, or run the thick oil for these racing conditions? I have the locking pin part mentioned on your site. Pretty sure everyone runs a spool out here. No carpet anywhere. Mostly Xrays and TC6s on the track.
People generally run 5.5-6.5mm for the two locations where they set it up every week. Track is decent sized but not huge. People run around a 3.6-3.8 FDR in VTA if that's any help.
Thanks!!
Hayling is offline
Old 01-29-2015 | 07:03 PM
  #599
Just finished my TT02 S-Spec kit. I set it up for VTA 25.5 but have not had it to the track yet.
Small changes I made from the kit:
Aluminum Steering Arms and middle connector
Aluminum center shaft
High Speed Gear Set (75/50 currently but yet to test at track)
Gear cover opened up to clear the 50t pinion
Shocks length set to 60mm front and 59mm rear. To do that I used 2mm front internal shock spacers and 2.5mm internal rear.
That gives rebound stroke about 2mm in rear and 3mm in front.
Moved rear shocks to outer lower mounting hole (otherwise car was too high even with no spring spacer)
2mm spring spacers front and rear gives me about 5mm ride height with VTA tires
I shortened the wheelbase at the back by moving the 3mm spacer (just to fit my existing body)
I shimmed to front and rear lower a-arms with some .2mm shims to take up play.
As a basic setup I put 1.5 camber all around. 1mm toe out in front.
I just kind of guessed based on how I have my 419 and 417 setup. I may get to run at the track this weekend.
ic-racer is offline
Old 01-30-2015 | 12:41 AM
  #600
I did build my TT-02 as a rally and used those TRF mini dampers with the TRF touring car short spring set.
The length of my dampers was 57,5mm at the front and 58,5mm at the rear.
I think the front had an inner spacer of 1mm and 0,5mm for the rear.
But all this was used with the standard suspension and not the suspension of the type-s (TB evo IV suspension arms)
At the end (cause i sold the car last week) i used TT-01 ball diffs at the front and rear, i prefer this over the standard geardiffs.
