HPI WR8 Flux/Ken Block H.F.H.V. Rally Car Thread
#46
#47
Can you put adjustable camber arms on the wr8
Check out my WR8
http://www.rctech.net/forum/members/...07-albums.html
Check out my WR8
#48
What proline wheels and tires will fit the WR8?
#49
The only Proline tires I'v run on my WR8 are the 110200 Road Rage 2.2 M2 Medium Street Tires. They fit reasonable well on the 2.2" WR8 rims and they look pretty cool:
I've never looked at proline wheels so I couldn't tell you there. They would have to have 12mm hexes and be 2.2" to look close to the WR8 scale.
#50
HPI has just released the new 2013 GRC Ken Block Livery...
Just in time for Mr. Block to update to the 2014 GRC livery... I wish HPI would keep on top of the WR8 and the GRC livery schedule. It's nice they released the 2013 version but in a few weeks everyone will be wanting the 2014 Block version.
#51
TBG just released over/under trays. And they even have one with a driver...
Pretty coolio!
2-door overtray
4-door overtray
Undertray
Driver
Pretty coolio!
2-door overtray
4-door overtray
Undertray
Driver
#52
Here are a few pictures:
Under tray:
4-door over tray:
2-door over tray:
First thing I noticed is the rear body mount is reversed which got me wondering how the kits clear with the stock Ford body and body mount orientation.
Time will tell I suppose.
Under tray:
4-door over tray:
2-door over tray:
#53
Neat! HPI did the top shell with driver in their original RS4 rally but belt drive and off-road did not mix well. I'm surprised they didn't do it for this one. I would probably leave it off for 3S operation. I wish I could use that lower cover on my WR8 3.0 but it needs every bit of its chassis for a heatsink.
#54
I was also thinking about that. I think with the height of the 4-door cover you would be able to get away with cutting a vent hole in the back seat without worrying about to much dirt coming in. You could maybe covering it with some mesh if you are worried about the dirt.
I run my WR8 on 3s almost exclusively. I'll let you know if I run into any issues with overheating.
#55
I never had very good luck with mine in the dirt. Seems like I was always digging tiny pebbles out of the diff teeth to unjam it all. I didn't have it long and sold that and an RS4 Sport to get the RS4 Pro 2. Ahh... the good ol' days. I still have the pebbles in the diff teeth problem with my Nitro RS4 to this day. The WR8 chassis has been pretty flawless for me. The stock servos on the other hand... bleh. I gotta change them soon.
#56
I agree the stock steering servo is crap on the WR8. I picked up a savox for $35 used on here and it made a world of difference. It's like it's a totally different car. I also glued the servosaver ring into the servosaver because it was loose and causing odd centering issues so that helped a bunch.
Plus after upgrading the WR8 servos I was able to put the SW-10 into my RS4 rally and it is the perfect speed and strength for it. win - win I suppose.
#57
Heh, yeah. I dunno why it seems like so long ago. I guess I consider the days before brushless, LiPo and 2.4 ghz to be the good old days. Back when we used to build all of our cars, solder our matched NiCads together and worry about range and frequencies. Those were the days! I miss building kits and that's about it. Things are so much better now!
I had a two RS4 minis. One was normal with the Miata body. The other was a monster mini with A-arms, shocks and axles from a Rally, wheels and tires from an MT and a Beetle body that I baja'd out with cut fenders and all that. It was crazy.
Other HPI's I've owned include the original Micro RS4, Super NRS4, two MT's, Savage 21 and Savage XS Flux. Been an HPI fan for a long time and went through many before finally settling on the three that I have now.
#58
That Monster Mini sounds pretty awesome man. You got any pictures of it anywhere?
After talking to the TBG guys I found the wheel/tire combo they had on the WR8 in the pictures.
These are 35mm x 80mm. They should be perfect for the WR8:
Hobbypro 1 10 on Road Rear Tire for Buggy RC Car H40 | eBay
And these are 30mm x 80mm. If you want to run a staggered setup I suppose you could order a set of these for the front:
Hobbypro 1 10 on Road Tire for Buggy F RC Car H39 | eBay
I'm going to order two sets of the 35mm wide ones and see how they hold up.
#59
Mike, let us know how is the tire material
#60
