Tamiya XV-01
#1862
Few xv01 tc pro questions
1. Think i know this one but can it use the xv01 reinforced belts?
2. 54514 xv01 stabilizer set is not compatible with the tc chassis but is a stabilizer set available if needed?
3. Do i use carbon reinforced /standard tb03 lower arms?
4. What is the max ride height?
#1863
2. You can use stabilizers set from TA05/06, TRF416, 417
3. Yes those are the arms
4. not sure I’ll let someone else answer
#1864
Modified XV-01 with active wing
#1865
https://youtu.be/fHCh87YLTpo
#1866
Controlled by throttle. Watch at 44 sec
#1867
No custom mix on transmitter. Just used a futaba sv servo which i programmed then used a y connector to throttle
#1869
I read the other day there will be a soft compound rallyblock tire from tamiya soon(item 54861). The only reference so far was only on tamiyablog.com, but a few online vendors have already created listings for the item but marked as not available yet. If this is the same compound as the super grip radials/superslicks it will be amazing. I mean even if it is the tamiya M2 compound it would still be a huge improvement and potentially a lot better than the HPI pirelli offerings.
#1870
The multi spoke rally wheels are where they should revisit. On almost all my cars, the inner support spoke reinforcements tend to run on my steering and a-arm components. Ive had to save them down quite a bit.
Thanks for the news
#1871
Great news! Though I still have the original Rally Block tires that came with my xv-01. I saved them because the street can really chew them up. I find even the original compound tires are really good on grass and dirt. What would the soft compound be used for? The originals worked well on the street tio because of the tread pattern. It has a very predictable grip and drift.
Thanks for the news
Thanks for the news
I would love to have more grip and have the car handle well in higher speeds also while driving off road. The Super grip Radial/Super slick tamiya compound is very sticky and quite close their slick type-a race compound, so if it is anything like that the handling will be very promising. Even the tamiya M2 compound (think of it is their Medium compound) would be a big improvement. Sure it could be that the car might lose a bit of its scale appeal since it might not drift as easily but I can live with that. I prefer to have a controllable car. My concern would tire life, but I guess we would have to wait and see about this one.
#1873
Thanks for the news
Thanks for the news
of positive offset. Starting with the TB03 arms, 26mm wheels started to rub.. but at that point majority were running 24mm wheels. Only kits that came with the 26mm wheels were TT and XV. The XV arms won’t have this issue as they are shorter as well and the upright has more of a + offset.
So if you’re experiencing this, it’s because you switched to XV01 TC arms, which are from TB03
#1874
That said, MST makes some interesting looking rally tires, but I have no clue if they are any good. They do look super realistic though.
#1875
My daughter is using them....
...on her TT-02, when she is in "Rally-mood". It seems that they work overall fine. Bei sure to go with the softer compound.
Regards,
Michael
Regards,
Michael
