Kyosho Touring Car
#1351
The car is really good, not sure how good in super high bite yet, we will see after nats. I was going to post my setup for The Gate, but I want to see how it works under higher traction at the capet nats.
I think the car is capable of being in the top ten in stock, there are some minor design issues, as there are in all new cars, but we are slowly overcoming them.
#1352
If anyone is interested in a Stallion, I have one in the for sale thread. -Ky
http://www.rctech.net/forum/showthread.php?t=151499
#1353
#1355
Yeah, rubber tire racing is against my religion....
#1356
Does Xrays 2007 springs fits on TF-5 Stallion? From what other car springs fits on our Stallion?
#1357
im using HPI springs , the all blk ones..
#1359
thanks King and Patrik
#1360
#1362
I run the Corally's and use corally shock bottoms, because our shock bottoms don't fit the spring diameter appropriatley. To run the x-ray springs you need to flip the spring collar over (if you have enough room, between the top of the shock cap, when you set your ride height) or you can turn down the collar on a lathe to remove the edge that locates the larger diameter spring.
On another note congradulations to Andy for making the main in touring stock at the carpet nats with his Stallion. Both of our stallion's worked well, I felt I had a good car, but lacked in the horsepower department. I also DNS in round 3 which really hurt, due to a brain fart on my part. I will post my final setup shortly.
#1363
I will post my final setup shortly.[/QUOTE]
can't wait also did you use the stock chassis?
#1364
did josh use his version of the stallion or did he use a regular one?
